Home > Maintenance & Modifications > Puma airbox removal
Page 2 of 3 <123>
Jim_Bean
Right - Thanks Steve. I thought there would be a way. It seems the dealers just don't have that level of patience.
They are now replacing the wheel arch liner! Hopefully nothing else will get damaged during this procedure.
Post #344459 11th Jul 2014 10:51am
That's what I'd do anyway, needs care though or the bit could pierce into the air box if not careful.
If they broke the bracket make sure you get it put right too. Or else. Rolling with laughter
Post #344464 11th Jul 2014 10:57am
KU310R
Malta
I am trying to remove the air cleaner housing from a 2.2 as well, but cant understand where the "3 bolts" (according to the manual) are. Any tips where to look please? Thanks!
Post #661478 2nd Nov 2017 7:48pm
MK
Its a pig to remove it. To say the less Puma 110" SW
Post #661569 3rd Nov 2017 3:44am
MartinK
I wonder when someone (Allisport, BAS maybe) will bring out a new airbox design...??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #661591 3rd Nov 2017 9:36am
JOW240725
I thought from all the research done on restriction to air intake that BAS was going to produce a new air intake system, but not seen anything yet.
Sorry KU310R, can't help you with your question. I'm sure I read a guide somewhere, so maybe try the search function on here? This may help? http://www.defender2.net/forum/topic56018.html?highlight=airbox James
Instagram @suffolk_rovers
Post #661595 3rd Nov 2017 9:45am
Coatesyyy
I've got to do this soon, looks like a swine to do Laughing
Post #661596 3rd Nov 2017 9:48am
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
When I installed my Safari snorkel about 3 years ago, from memory I think I removed the headlight assembly to gain better access to the air box as I did not want to drill out the air box support bracket rivets. I used some dish washing liquid with a bit of water and coated the fixtures after removing the support bolts. As the studs passing through the rubber grommets are tight, you need to move/rock the box around a little to allow the lubricant to get into the joint to allow slip. Mine has air conditioning so the outer foam needed protecting so as not to get damaged when removing the box. I did not disconnect the air conditioning hose.
I was still difficult to remove but I got it out. Hopefully I won't have to do it again for a very long time.
Post #661603 3rd Nov 2017 10:13am
I think it is only difficult if you have a/c.
I've had the airbox on and off repeateadly while sorting out various issues and improvements on my (non a/c) 2.4, with no real problems, although it is a bit of a fiddle.
One thing that makes it much easier is if you shorten the plastic prongs on the airbox the first time you get it off, and lubricate the rubber doobries with vaseline before refitting.
Also, take the lid off the airbox, and remove the entire lid complete with air hose from the turbo and hence from the car to give yourself more room.
Post #661645 3rd Nov 2017 3:19pm
KU310R
Malta
Thanks for your help and suggestions. I ended up cutting the originial air intake and doing all the modifications with the airbox in place since there was the A/C line on top of it and wasn't sure it would go through without breaking something.
Post #661760 4th Nov 2017 2:45am
I always but put a disposable glove over any open hose outlets or inlets too, keeps any debris out completely whilst removing or refitting.
Only remove just before reconnecting. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #661862 4th Nov 2017 6:26pm
KU310R
Malta
Thats what i did as well. I used some tape to cover inlets instead. Gloves are a better idea though!
Post #661886 4th Nov 2017 9:28pm
Tapes good for smaller stuff I find. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #661899 4th Nov 2017 10:37pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Just wanted to confirm that it is possible to remove the airbox on an aircon Defender and without drilling out the rivets, or unbolting the aircon.
As mentioned you have to loosen up the 4 rubber grommets, then undo the 3 bolts and let the bracket drop. Top Fan shroud needs to come off and unbolting the lower one, which can't be taken off but at least moved around. Trick is to get the airbox inlet pipe facing the direction of the belt/ fan.
Reinstatement goes similar with the bracket attached by only one bolt (closest to the shock), hanging downwards. Drop the airbox inlet pipe first and then pull across to get the rest of the box under the wing.
But be warned, it is a Censored of a job. m
Post #695327 21st Mar 2018 10:34pm
What were the JLR engineers thinking...
Post #695449 22nd Mar 2018 4:51pm
Page 2 of 3 <123>
