Home > Maintenance & Modifications > Service time - new versus old
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
As if I needed reminding. They don’t make ‘em like they used to.......
Post #660940 31st Oct 2017 6:07pm
williamthedog
Yes the pumas filter seems pretty insignificant.
It does its job though. The filter housing is flimsy, ok as long as you don't drop it 😏
Post #660942 31st Oct 2017 6:19pm
X4SKP
Hello v8bobber
I thought the same when first 'confronted' with the Cartridge vs Steel (how they should look) version... Shocked
'load' the Cartridge (Filter) with new oil prior to fitting into Filter Housing
Replace large Rubber O Ring around Filter Housing (also oiled)
and whilst the Housing 'states' (is marked) to tighten to 25NM...
press on until you reach 35NM... or she'll leak... Embarassed
Good Luck SKIP
Post #660960 31st Oct 2017 7:21pm
v8bobber
Have serviced the Puma a few times so an old hat at it but just happened to put the new filter down next to one due to go on my old 90 and really reinforced the diffence in size.
Maybe the new oil filters are made by the same people that make Mars bars as they were bigger when I was younger aswell!!
Post #660964 31st Oct 2017 7:28pm
Grenadier
Playing devil’s advocate, but have you ever opened the white casing up to see how big the filter inside is, as opposed to the body? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #660965 31st Oct 2017 7:34pm
X4SKP
They have 'form'... some things just shouldn't be messed with... Shocked
 SKIP
Post #660966 31st Oct 2017 7:36pm
zsd-puma
to be honest the paper elements aren't a new idea. It's what cars used to have before there were the spin on filters, the old metal housings for them were awful leak prone things, unlike the modern plastic ones. The spin on ones probably only have the same size element in them.
Post #660971 31st Oct 2017 7:55pm
UtilityTruck
One area where the 2.2 beats the 2.4? Proper metal disposeable filter 2014 Keswick Utility 2.2
Post #660989 31st Oct 2017 8:53pm
zsd-puma
I'm not really sure it makes much difference really. Marginally less messy than fishing the element from the plastic housing but thats about all.
Post #661025 31st Oct 2017 10:08pm
