Home > V8 > The adventures of the V8_Ninety
Page 9 of 10 <12345678910>
L110CDL
Forgive me GREENI Rolling Eyes but what has it got over the one you have just took out ? i dont know much about gearboxes Neutral Clayton.
Keeper.
Post #660371 29th Oct 2017 10:03pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Not jealous, not jealous........ slumps head and walks away to his Lt-85 Rolling with laughter still mines a manual and I like that Whistle
Looks great Greeni Thumbs Up , one day you may settle on your setup Rolling with laughter 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #660403 29th Oct 2017 11:24pm
Every day's a school day Clayton, hope this throws some light on it.
The old box was out of a very old 3.5 RRC, so was quite tired and not really locking up properly, with the 4.6 being a spunk load more powerful, I was finding that on steep ascents up the Peaks it was flaring (like a manual clutch slipping). No Bueno.
It wasn't really the right box to bolt behind a funky fresh 4.6, but the costs had spiralled high and I needed to just get it on the road and use it.
I turned to Ashcrofts as they can build them with bigger/stronger internals..
The photos show parts from a standard box 22 and the strengthened parts 24.
One way clutch
Planetary gears
Plates
Torque converter, the left one is for a 300tdi td5 for eg, middle RR 3.9 and tuned td5, right for 4.6+
A larger converter is desirable on a tuned engine for a few reasons :
1) Lower stall speed, there's little point in having a nice torquey engine if the converter is not transferring the drive and you are revving straight past it. A larger converter will reduce these revs and allow you to take up drive earlier which results in much more relaxed driving. This is by far the biggest advantage of upgrading the converter. Note these reduced revs are not to be confused with lower gear shift points, these stay the same as they are determined by the autobox ECU programming.
2) Less heat generation because of the lower stall speed and reduced 'slip'.
3) The converter has a lock up clutch inside and the smaller one struggles to cope with a stock engine, never mind a tuned one. This clutch can slip as you accelerate when it should be staying locked. In a TD5 the stock converter is the small one. If you have a stock engine, stick with the stock converter. If the engine has a mild tune then we would recommend upgrading to the medium diameter one. QRZ 2e0vpf
Post #660466 30th Oct 2017 8:58am
Stuff QRZ 2e0vpf
Post #660469 30th Oct 2017 9:14am
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I learned stuff.
Thumbs Up 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #660473 30th Oct 2017 9:26am
Zed
Either colour would look great but I would go for body colour wheels. Is it Keswick green? I remember seeing a Cool'nVintage rag top 90 that looked absolutely stunning with that combo.
Post #660477 30th Oct 2017 9:37am
Kit Laughing
Zed, thanks, I'm leaning towards body colour.
I need somebody clever who can photoshop the colour on Thumbs Up QRZ 2e0vpf
Post #660478 30th Oct 2017 9:51am
Mash
*spanner in the works*
I'd vote cream as it's a great colour combo not that I'm biased as I'm going that classic look route Whistle 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #660479 30th Oct 2017 9:57am
Kit
Rolling with laughter 1993 200 Tdi 90 CSW
Post #660481 30th Oct 2017 10:00am
Edit QRZ 2e0vpf
Post #660511 30th Oct 2017 11:19am
L110CDL
Many thanks GREENI i have learnt a great deal, thank you again Bow down Clayton.
Keeper.
Post #660711 30th Oct 2017 9:46pm
L110CDL
Another spanner for you GREENI Very Happy
What about the galvanised colour rims to match the bumper, hinges and wheel carrier ? it's just a thought as i cant make up my mind Neutral Clayton.
Keeper.
Post #660713 30th Oct 2017 9:50pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Rolling with laughter that badge is great Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #660717 30th Oct 2017 9:53pm
Ian Thumbs Up
Clayton, bizarrely I was thinking I've never seen that before, earlier. There's probably a reason for it. QRZ 2e0vpf
Post #660722 30th Oct 2017 10:08pm
L110CDL
Laughing Thumbs Up Clayton.
Keeper.
Post #660744 30th Oct 2017 10:43pm
