![]() | Home > V8 > The adventures of the V8_Ninety |
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
Not jealous, not jealous........ slumps head and walks away to his Lt-85
Looks great Greeni 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Every day's a school day Clayton, hope this throws some light on it. The old box was out of a very old 3.5 RRC, so was quite tired and not really locking up properly, with the 4.6 being a spunk load more powerful, I was finding that on steep ascents up the Peaks it was flaring (like a manual clutch slipping). No Bueno. It wasn't really the right box to bolt behind a funky fresh 4.6, but the costs had spiralled high and I needed to just get it on the road and use it. I turned to Ashcrofts as they can build them with bigger/stronger internals.. The photos show parts from a standard box 22 and the strengthened parts 24. One way clutch
Planetary gears
Plates
Torque converter, the left one is for a 300tdi td5 for eg, middle RR 3.9 and tuned td5, right for 4.6+
A larger converter is desirable on a tuned engine for a few reasons : 1) Lower stall speed, there's little point in having a nice torquey engine if the converter is not transferring the drive and you are revving straight past it. A larger converter will reduce these revs and allow you to take up drive earlier which results in much more relaxed driving. This is by far the biggest advantage of upgrading the converter. Note these reduced revs are not to be confused with lower gear shift points, these stay the same as they are determined by the autobox ECU programming. 2) Less heat generation because of the lower stall speed and reduced 'slip'. 3) The converter has a lock up clutch inside and the smaller one struggles to cope with a stock engine, never mind a tuned one. This clutch can slip as you accelerate when it should be staying locked. In a TD5 the stock converter is the small one. If you have a stock engine, stick with the stock converter. If the engine has a mild tune then we would recommend upgrading to the medium diameter one. QRZ M8VPF |
Stuff QRZ M8VPF
| Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110
I learned stuff.
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3362
Either colour would look great but I would go for body colour wheels. Is it Keswick green? I remember seeing a Cool'nVintage rag top 90 that looked absolutely stunning with that combo.
Kit
Zed, thanks, I'm leaning towards body colour. I need somebody clever who can photoshop the colour on |
*spanner in the works*
I'd vote cream as it's a great colour combo not that I'm biased as I'm going that classic look route 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Edit QRZ M8VPF
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11094
Many thanks GREENI i have learnt a great deal, thank you again
Another spanner for you GREENI
What about the galvanised colour rims to match the bumper, hinges and wheel carrier ? it's just a thought as i cant make up my mind 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
Wanted, Forward Control Anything considered. |
Ian
Clayton, bizarrely I was thinking I've never seen that before, earlier. There's probably a reason for it. QRZ M8VPF |
