Home > Maintenance & Modifications > Rear arch spare fuel tank.
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Has anyone fitted the 45L rear arch tank from Britpart.Are they made well?It seems straight forward to fit or am I wrong.I'm hoping that the main tank does not have to come out to fit the filler tube. Puma 110 SW
90 V8 SOFT TOP
Post #66063 3rd Apr 2011 6:58pm
BigMike
Can't comment on the tank itself, but you'd have to pay me to use Britpart stuff. And even then it'd have to be a lot.
Post #66064 3rd Apr 2011 7:01pm
LESVOSD110
It may be a Frontrunner product. Puma 110 SW
90 V8 SOFT TOP
Post #66065 3rd Apr 2011 7:05pm
BigMike
Really? I thought All Makes imported front runner along with flatdog? Didnt think Britpart had a deal with front runner
Have you looked at the safari equipment tanks? www.safari-equip.co.uk
Post #66067 3rd Apr 2011 7:08pm
leeds
That is listed as being suitable for
Quote:
Defender 110 - after 1999 (plastic tank, Td5 and the new Td4 models)
Be very careful here. It also depends on the tyres you run as well!
We have a 96 110 300TDi on 255/85/R16 M/T. Have run this with a wing tank and these tyres for many years. The tyres OR mud etc on tyres just touch the tank on full articulation. Evidence is a small scuff mark on the arch tank.
On our 09 110 Puma on same tyre we fitted the same tank. A visual inspection showed that the bottom leading edge of the arch tank would foul the tread on the tyres. NOT good news if at speed the tyre tread was caught by the tank. Something would go bang when the tyre got caught.
Safari Equip had to alter design of arch tank for Pumas. So if getting the Britpart one ensure they state that it is compatible with your tyre size.
Fitting the wing tank should be relatively straight forward. Best done on a 4 post ramp with wheel off
HTH
Brendan
Post #66068 3rd Apr 2011 7:12pm
LESVOSD110
Britpart sell frontrunner roof racks.I may be wrong about the tanks,but looking into it.Yes,I've looked at the SE ones. Puma 110 SW
90 V8 SOFT TOP
Post #66070 3rd Apr 2011 7:15pm
leeds
The Safari Equip ones can be made from aluminium mild steel or stainless steel.
There is no after market fuel tank guard for a wing tank. Safari Equip will double bottom them for you on request giving a 4 mm(?) bottom. Extra cost with double bottom is about £40 I believe.
If you need any help with the Safari Equip gear give me a shout as I am only 2 miles away from them
Brendan
Post #66071 3rd Apr 2011 7:21pm
LESVOSD110
HTH
Brendan
I run 235/85/16 and not going any larger so should not have rubbing problems. Puma 110 SW
90 V8 SOFT TOP
Post #66072 3rd Apr 2011 7:21pm
LESVOSD110
Brendan
Thanks.You know were you should be,,,,, Whistle ........ :rolllaugh:Cheers Brendan Puma 110 SW
90 V8 SOFT TOP
Post #66074 3rd Apr 2011 7:24pm
leeds
Difference in tyre diameter between a 255/85/16 and a 235/85/16 is 34mm or 17mm on radius.
I would say that the smaller tyre would have cleared the old style SE wing tank but I would still check with Britpart to make sure as you are so far away.
It is better to ask questions first and try to avoid potential problems
Brendan
Post #66076 3rd Apr 2011 7:30pm
leeds
Do not worry that side of life is being well looked after! Whistle Also we have our own plans in about two weeks time Wink Whistle
Brendan
Post #66078 3rd Apr 2011 7:32pm
LESVOSD110
I will check with them. Puma 110 SW
90 V8 SOFT TOP
Post #66079 3rd Apr 2011 7:33pm
jst
i have a 45L (ish) tank from Brendan, i must admit to not fitting it yet, but its for a Puma with the afroementioned 255.85s and i asked for it to be made to make sure it wouldn't foul the tyres. Its certainly well made and good value for money too. As my trip this year is on hold (of a sorts) the rush to fit it has passed. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #66085 3rd Apr 2011 9:14pm
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Might not be of help. I have the Big Countryone here is South Africa. The guy pointed out the differences between Big Country and Frontrunner. Frontrunner is 45l and thus it's too far out (Too much volume). Rubbing happens on the wheels. His tank is 40 l but also the side exposed is arched, not straight. My 2CW.
Post #66095 4th Apr 2011 6:53am
Schulli
Germany 2011 Defender 110 Puma 2.4 SW Santorini Black
Marius,
Do you have a Link to that product? I can't find it on their webpage.
Thanks
Schulli
Post #66096 4th Apr 2011 7:40am
