![]() | Home > Maintenance & Modifications > Rear arch spare fuel tank. |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
Sorry.....I meant to say Big Country....
![]() Here is the link to their site. I'm verry happy with my tank! http://www.bigcountry4x4.com/Products.aspx?ProductTypeID=13 Can try to post pics if anyone wants? |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
Hi. Do you know what tyres he is runing? Puma 110 SW 90 V8 SOFT TOP |
Thanks for link.Please post some pics if you can. Thanks Puma 110 SW 90 V8 SOFT TOP |
To fit one of these tanks to puma with plastic main,do you have to drill a hole for what is called a balance pipe.From what I have read,on metal tanks (TD5) you use the drain plug.
I'm not keen to make a hole in my main tank. ![]() 90 V8 SOFT TOP |
How do I upload fotos of this tank?
Hopefully this does it:
![]() Click image to enlarge ![]() Click image to enlarge |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
simples
Thanks Marius. Did you have drill your main tank to fit a balance pipe? Puma 110 SW 90 V8 SOFT TOP |
No, I had the tank fitted so I'm not sure what they did unfortuanately...
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
I have not had one fitted, but belive that no holes are drilled into your tank, they connect it via the breather pipe on your old tank.
Andy |
They do connect via breather for vapour breathing,but for the tank to empty,there is a balance pipe.On the older steel TD5 tanks they linked via the drain plug.I do not know if ther is a change on the plastis tank. ![]() 90 V8 SOFT TOP |
