![]() | Home > Td5 > another strange thing.... |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2228 ![]() ![]() ![]() |
The arm could have been refitted in a slightly different position, you could either reposition so it doesnt happen anymore. Or adjust the stop locks
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 ![]() ![]() |
Yep agree with the above, seems like the arm is now slightly out
neverin Member Since: 26 Sep 2016 Location: worksop Posts: 47 ![]() ![]() ![]() |
How could the arm be out? Kerbed? Pot holes?
Should I have the tracking done? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
Two comments-
1. If it was the pump that was replaced rather than the box (as the OP states), the drop arm won't have been touched. Adjusting the drop arm cannot cause tyre rub if the lockstops are correctly set anyway. 2. Other than the lockstops, the only thing that could cause this is if the tie rod has been adjusted to alter the tracking. If it has been shortened to reduce toe-in, tyre rubbing could ensue. I suggest getting the tracking checked then adjusting the lockstops correctly. |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 990 ![]() ![]() ![]() |
^^^^ what Blackwolf said^^^. Get the alignment checked. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
the tracking was miles out. they adjusted it and now the wheel doesnt catch.
gut they also found that the track rods? rubber was split on both sides and the big wheel ball joints seem to be leaking grease. Are there any drawings of the td5 steering system so i can identify the bits? |
not drawings of the td5 steering system so i can identify the bits, but parts
https://www.landroverworkshop.com/ |
