Home > Td5 > another strange thing....
neverin
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Have just had the steering pump replaced and since then if i put full steering lock to turn left going forwards or to reverse then inside of the passenger side front tyre rubs on the chassis.
its fine when full lock is done to the right.
When driving in a straight line the steering wheel is slightly to the left.
Are there limit stops that might have come off?
Anybody have any advise?
Thanks
Post #658465 19th Oct 2017 10:21pm
bankz5152
The arm could have been refitted in a slightly different position, you could either reposition so it doesnt happen anymore. Or adjust the stop locks
Post #658479 19th Oct 2017 10:59pm
Coatesyyy
Yep agree with the above, seems like the arm is now slightly out Thumbs Up
Post #658480 19th Oct 2017 11:03pm
neverin
How could the arm be out? Kerbed? Pot holes?
Should I have the tracking done?
Post #658482 19th Oct 2017 11:13pm
Two comments-
1. If it was the pump that was replaced rather than the box (as the OP states), the drop arm won't have been touched. Adjusting the drop arm cannot cause tyre rub if the lockstops are correctly set anyway.
2. Other than the lockstops, the only thing that could cause this is if the tie rod has been adjusted to alter the tracking. If it has been shortened to reduce toe-in, tyre rubbing could ensue.
I suggest getting the tracking checked then adjusting the lockstops correctly.
Post #658483 19th Oct 2017 11:22pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
^^^^ what Blackwolf said^^^. Get the alignment checked. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #658572 20th Oct 2017 2:04pm
neverin
the tracking was miles out. they adjusted it and now the wheel doesnt catch.
gut they also found that the track rods? rubber was split on both sides and the big wheel ball joints seem to be leaking grease.
Are there any drawings of the td5 steering system so i can identify the bits?
Post #658764 21st Oct 2017 5:19pm
dorsetsmith
not drawings of the td5 steering system so i can identify the bits, but parts
https://www.landroverworkshop.com/
Post #658780 21st Oct 2017 6:13pm
