![]() | Home > My Defender > V8 90 Project |
Hi LRA, I know your concern and thanks for the advice, I was going to stick with standard bolts but these are the ones sold by YRM for the locations I am fitting, they are graded at A4-80 which matches the metric grade of 8.8. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Ah ha, fair enough! Darren
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11052 ![]() ![]() |
^^^ +1
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 ![]() ![]() |
A lot of work but going to be a beauty that!
Okay after my little trip away I've managed to get a few hours in on the V8, it was rubbish weather so I decided to tackle the engine, I have spent some time cleaning it but I think it's a longer process yet
![]() The gunk I have removed from the heads/rocker covers has been mental. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge It is amazing what a bit of Tlc can give you, a few more hours and it should be clean enough for some paint, then once built and fitted the test fire will no doubt coat the thing in oil and grime and the natural balance will be restored ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
What's the mileage on the V8?
Is it just a strip/clean/inspect, I've looked at mine now, and I think it's long overdue a camshaft ![]() Yours looks the same as mine, suffering from the "Black Death" ![]() Wanted, Forward Control Anything considered. |
Not too sure on the mileage I will have a rummage in the box marked x to confuse the enemy my speedo is hiding in
![]() The black sludge I think Stems from a few missed services and the time it's been stood still, the sump oil was still fresh when I got it. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Nice work there Mash, a bit more tlc and it will look good as new
Okay a little bit of a boring update as pics of cavity waxing are far from exciting but with two litres pumped into the chassis I think I have covered most of it, my endoscope should be back in the uk tomorrow so I will have to check.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge One things for sure this chassis should last me a long time even in Guernsey ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Loving the workshop QRZ 2e0vpf
So do I but I only get to use it in the evening or weekend
^^^ That is better than not at all
okennedy Member Since: 12 Sep 2017 Location: Roscommon Posts: 42 ![]() ![]() |
Another great thread!
