![]() | Home > Maintenance & Modifications > Lowered defenders with larger than OEM tyres? |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2234 ![]() ![]() ![]() |
Why not fit a step instead?
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I'd prefer not to as i've got rock sliders fitted, past experience of them isn't great either 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
Ahhh I've gotcha. I was in a similar place a few months ago (small lift, 285 tyres) went through many ideas and eventually came to the conclusion of "its their problem not mine"
![]() I keep a lil step in the boot for anyone that really needs it, which so far is only my 80 year old grandma. She always says "well if the Queen can drive one I can certainly get in one" ![]() On a serious note me and a mate came up with another idea that may benefit you too, that is if you want to keep your current height. Basically involved welding some thick box/rectangle section onto the bottom of the rock sliders and building a detachable step that would slide into in to it. Would be pretty cheap and quite easy to do (providing you can weld/know someone). Step/mini ladder allows people to get in easily but can be removed for off roading so no damage done. Make sense? Plus I found fitting a handle into the A-Pillar made everyone happier too, just need some longer screws, washers and a handle. Could even use the Naka leather ones if ya wanna be fancy! - ![]() Click image to enlarge |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7944 ![]() ![]() ![]() |
I saw someone post a photo of a small fold up step, tied with a length of string to the door hand so once in you can hoik the step up into the footwell. Job done
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
![]() 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141 ![]() ![]() ![]() |
Wow! Did not know you kept a photo of my wife. Though I can see why you would being the beauty that she is, she has now shaved the beard off. I keep telling her to grow it back as it hid her twisted teeth and her deformed chin. ![]() http://www.youtube.com/user/conwy1 |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
![]() Click image to enlarge Alive Comfort springs, 285/60R18 Cooper LTZ, 30mm spacers ![]() |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
![]() Click image to enlarge Alive springs. Can't remember tyre size. It's dark outside too. Vastly improves the ride, especially if you keep standard dampers. QRZ 2e0vpf |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
I have 1" lowering spring and 285 BFGs, no problems at all. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Sounds promising, what alloys are you running jeffers, any spacers? 1993 200 Tdi 90 CSW
Running on boost alloys. Don't know if you have spacers or going to fit them but without spacers the 285s may foul chassis etc so you will then have to adjust the stop bolts and loose a bit of turning circle. Jeff
I forgot about your DCPU, makes me want to get 18" boosts ![]() 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
