Home > Maintenance & Modifications > Lowered defenders with larger than OEM tyres?
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I'm getting quite allot of earache about the defender being too high, and if I put 255/85/16 tyres on, that's only going to get worse.
Currently i've got aftermarket HD springs on it, which push it up about 1" over stock I would say... if I were to fit the Alive comfort springs and shocks that will knock it down about -2" from what it is at the moment.
What size tyre can I run without any problems?
(if anyone has any photo examples, that'd help me decide what to do as well) 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #656530 11th Oct 2017 12:11pm
bankz5152
Why not fit a step instead?
Post #656532 11th Oct 2017 12:16pm
Kit
I'd prefer not to as i've got rock sliders fitted, past experience of them isn't great either 1993 200 Tdi 90 CSW
Post #656533 11th Oct 2017 12:18pm
bankz5152
Ahhh I've gotcha. I was in a similar place a few months ago (small lift, 285 tyres) went through many ideas and eventually came to the conclusion of "its their problem not mine" Laughing
I keep a lil step in the boot for anyone that really needs it, which so far is only my 80 year old grandma. She always says "well if the Queen can drive one I can certainly get in one" Laughing
On a serious note me and a mate came up with another idea that may benefit you too, that is if you want to keep your current height.
Basically involved welding some thick box/rectangle section onto the bottom of the rock sliders and building a detachable step that would slide into in to it. Would be pretty cheap and quite easy to do (providing you can weld/know someone). Step/mini ladder allows people to get in easily but can be removed for off roading so no damage done. Make sense?
Plus I found fitting a handle into the A-Pillar made everyone happier too, just need some longer screws, washers and a handle. Could even use the Naka leather ones if ya wanna be fancy! -
Post #656538 11th Oct 2017 12:43pm
JOW240725
I saw someone post a photo of a small fold up step, tied with a length of string to the door hand so once in you can hoik the step up into the footwell. Job done Whistle James
Instagram @suffolk_rovers
Post #656542 11th Oct 2017 1:05pm
Kit
 1993 200 Tdi 90 CSW
Post #656548 11th Oct 2017 1:54pm
bankz5152
Laughing Laughing Laughing sorry for not answering your original question
Post #656550 11th Oct 2017 1:56pm
Kit
Rolling with laughter 1993 200 Tdi 90 CSW
Post #656557 11th Oct 2017 2:50pm
gilarion
Kit wrote:
Wow! Did not know you kept a photo of my wife. Though I can see why you would being the beauty that she is, she has now shaved the beard off. I keep telling her to grow it back as it hid her twisted teeth and her deformed chin. Rolling with laughter For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #656607 11th Oct 2017 6:59pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Alive Comfort springs, 285/60R18 Cooper LTZ, 30mm spacers Thumbs Up
Post #656612 11th Oct 2017 7:52pm
Alive springs. Can't remember tyre size. It's dark outside too.
Vastly improves the ride, especially if you keep standard dampers. QRZ 2e0vpf
Post #656624 11th Oct 2017 8:33pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
I have 1" lowering spring and 285 BFGs, no problems at all. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #656718 12th Oct 2017 8:43am
Kit
Sounds promising, what alloys are you running jeffers, any spacers? 1993 200 Tdi 90 CSW
Post #656723 12th Oct 2017 9:23am
jeffersj
Running on boost alloys. Don't know if you have spacers or going to fit them but without spacers the 285s may foul chassis etc so you will then have to adjust the stop bolts and loose a bit of turning circle. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #656766 12th Oct 2017 12:55pm
Kit
I forgot about your DCPU, makes me want to get 18" boosts Shocked 1993 200 Tdi 90 CSW
Post #656897 12th Oct 2017 9:19pm
