Home > Off Topic > CB
Page 2 of 4 <1234>
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Thanks Mark looking at fitting the Aeriel to the winch bumper NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65549 29th Mar 2011 10:07pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
BigMike wrote:
Landie Boy wrote:
Does that company offer the ability to fit them?
Jack
which?
The http://www.4x4cb.com site.
Thanks Jack
Post #65551 29th Mar 2011 10:19pm
Just be aware that the Whip will/can damage paintwork Thumbs Up
Post #65562 30th Mar 2011 6:39am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Fekete, I have a sirion ariel and gutter mount you can have, needs a new cable attaching, only thing I would say is the wire through the back door is a pain and eventually ends up damaged. But the ariel is good and top of the range. I have a roof mount on the 110 and needed a different ariel other wise I would have kept it. I mounted my CB on the back of the cubby box just used wood screws into the cubby.
Unfortunately I'm away so couldn't post it until 7/8th apr. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #65563 30th Mar 2011 6:43am
fekete
Willy thats sound mate i don't need it till the laning trip so could pick it up then when we meet...i'll get the rest of the kit and cable and get it all wired up ready Thumbs Up
Ken thanks for the advice mate Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65565 30th Mar 2011 7:09am
willy eckerslike
Sorted Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #65567 30th Mar 2011 7:27am
Just a heads uo I've taken a Albrecht AE6890 Multichannel CB Radio - with Remote Head
out of the D3
Great condition £80.00 plus P&P
Post #65569 30th Mar 2011 7:52am
mse
thunderpole are also good www.thunderpole.co.uk (and cheap) Mike
Post #65571 30th Mar 2011 8:08am
BBSJK
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
What do you guys think of handhelds as an options for short distances?
Jonathan No the other left . . .
Post #65578 30th Mar 2011 9:12am
Ken you have a PM...
Handhelds are not the best to be honest...you have to keep putting them down, they're more bulky than just putting a mic. down, range is pretty limited....I'd say not to!
Here's my HF set in my other 90..
Post #65579 30th Mar 2011 9:21am
mse
I have a handheld - older version of the current Midland and its great.
Has a few advantages over a fixed unit - especially when spotting for others, as you can take it with you - its also not car limited or in need of SWR'ing.
The range can be less - but i fitted a window clamp mount for an external aerial - which improves it...but for convoys and most the the P&P sites i have noticed any problems.
Ive got the cheap earpiece stuff to make it hands free if required (which is good) and you can strap it to anything or anywhere.
Overall - i dont think they are good...but different to a fixed unit Mike
Post #65580 30th Mar 2011 9:26am
BigMike
Handhelds are fine but rattle about and can be a hazard in the vehicle. if its for greenlaning the short range isnt an issue.
Post #65583 30th Mar 2011 9:28am
mse
This is the new version of mine, with a new fancy car mounting kit
http://www.thunderpole.co.uk/midland_42_plus.htm about the same price - ive had mind for about 10-15yrs Mike
Post #65587 30th Mar 2011 9:47am
BigMike
Must admit that mounting a CB in a suitable place in a puma isnt that easy (I've found anyway). Mind is wedged between the drivers seat and the cubby box with a piece of closed cell foam. It holds it pretty tightly and it doesn't ever move.
Post #65589 30th Mar 2011 10:09am
Lorryman100
That's the one I'll be ordering Mike http://www.4x4cb.com/public/item.cfm?itemID=631 along with this http://www.4x4cb.com/public/item.cfm?itemID=1133
Looked at getting the roof console to mount a vehicle cb in, just can't justify the cost or use as it would only really get used when green laning with others. The good thing about the midland handheld is that you get a lot of options with it as standard including the option of mounting an external Ae. Plus it's 4w output, so with an external Ae it will be good enough for what I need it for, my set-up will be a Midland 42, mag mount and a Thunderpole SS Orbitor Ae or a Sirio Hi-Power 3000PL with the MAG145PL magnetic mount.
Post #65602 30th Mar 2011 12:26pm
Page 2 of 4 <1234>
