Home > Off Topic > CB
Page 3 of 4 <1234>
BigMike
Where are you going to put the aerial Bri?
Post #65603 30th Mar 2011 12:27pm
Lorryman100
Probably on the roof Mike, but will need to look at the swr for the earth ground plane.
Post #65604 30th Mar 2011 12:29pm
BigMike
A mag mount? The roof is aluminum though... Thumbs Up
Post #65605 30th Mar 2011 12:31pm
Lorryman100
Yes, but the rib's are steel Question
Post #65606 30th Mar 2011 12:32pm
BigMike
Yes but will it not be cock-eyed? the mount I mean? unless its big enough to cross two ribs?
Post #65608 30th Mar 2011 12:40pm
Lorryman100
Probably Whistle Short of using a gutter mount or drilling and mounting a permanent fixed option I don't really see another way of roof mounting? I will do a bit of trial and error with the location and the use of swivel adaptors to try and resolve it. The other way I'm thinking about is to mount a fitting onto the Entreq engine cover ( It's Aluminium, so will need to run a 10mm cable to chassis of off mount to gain earth), but I'll need to reinforce the fittings onto the wing Question This is the main reason for going with a handheld unit with it's own Ae, less hassle Wink
Post #65610 30th Mar 2011 12:48pm
BigMike
If it's just for green laning then I wouldnt bother with an external aerial at all, you wont need one. my mount is the one post earlier but you have to drill to fit it. it's not as much of an a******* clencher as you might think Laughing
Post #65612 30th Mar 2011 1:05pm
Lorryman100
Really.......... Laughing Bow down
Post #65613 30th Mar 2011 1:09pm
BigMike
no really Laughing as long as you put masking tape over the area, measure it etc, then i just used a sharp punch to create a small depression to stop the drill slipping
Post #65614 30th Mar 2011 1:10pm
Lorryman100
Thumbs Up
Post #65615 30th Mar 2011 1:24pm
BigMike
I'm about to get one of those giant orbitors for our forthcoming trip. I usually use the short one which is fine for greenlanes and better for tree branches etc but for long distance the big one is the way to go Thumbs Up
Post #65617 30th Mar 2011 1:27pm
mse
Brian...i like mine, im sure it will work for you... as i mentioned i have a special clamp, you put it on the glass shut the window and on the outside it gives you a BNC and the inside you get whatever connection you need on the end of a cable.
You then plug in to the unit (i also use my airband transceiver if im on an airfield) and away you go! Mike
Post #65655 30th Mar 2011 5:34pm
fekete
ken wrote:
Just a heads uo I've taken a Albrecht AE6890 Multichannel CB Radio - with Remote Head
out of the D3
Great condition £80.00 plus P&P
Ken i'll have it mate Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65659 30th Mar 2011 5:52pm
NoDo$h
Oh cock, why didn't I see this before I popped in to see Ken Big Cry
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #65710 31st Mar 2011 12:09am
Sold to GREENI pending paypal Thumbs Up
Post #65713 31st Mar 2011 6:16am
Page 3 of 4 <1234>
