![]() | Home > Off Topic > CB |
Where are you going to put the aerial Bri?
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Probably on the roof Mike, but will need to look at the swr for the earth ground plane.
A mag mount? The roof is aluminum though...
Yes, but the rib's are steel
Yes but will it not be cock-eyed? the mount I mean? unless its big enough to cross two ribs?
If it's just for green laning then I wouldnt bother with an external aerial at all, you wont need one. my mount is the one post earlier but you have to drill to fit it. it's not as much of an a******* clencher as you might think
Really.......... ![]() ![]() |
no really
I'm about to get one of those giant orbitors for our forthcoming trip. I usually use the short one which is fine for greenlanes and better for tree branches etc but for long distance the big one is the way to go
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
Brian...i like mine, im sure it will work for you... as i mentioned i have a special clamp, you put it on the glass shut the window and on the outside it gives you a BNC and the inside you get whatever connection you need on the end of a cable.
You then plug in to the unit (i also use my airband transceiver if im on an airfield) and away you go! Mike |
Ken i'll have it mate ![]() |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
Oh cock, why didn't I see this before I popped in to see Ken
![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Sold to GREENI pending paypal
