![]() | Home > Td5 > Hub mess |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
OPs post made me think I have never checked my front drive flanges, so whipped off the wheels, drivers side rubber cap had a very very small amount of rust powder in it, removed the drive member bolts and cir-clip pulled off the flange and all was good nice snug fit but was dry with evidence of rust starting to form, passenger side was all like new, reassembled both sides with copious amounts of corrosion block grease. All in took 2 hrs but that included some time searching for flange gaskets and the thread lock I knew I had somewhere but couldn't find when I needed it. DEFENDER 90 TDCI XS,
dont envy you that, generally jobs on my cars go OK but both have been liberally coated with ACF50 regularly from new, the house is another matter everything I try to do or pay someone to do results in rework or damage, mainly due to bodges by previous owners DEFENDER 90 TDCI XS,
Cactus79 Member Since: 09 Jan 2017 Location: Cheshire Posts: 51 ![]() ![]() |
Small Victory!!!!!
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 ![]() ![]() |
Haha getting there mate
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 ![]() ![]() ![]() |
Need to do that with my filler plugs, both rusted in solid
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello Cactus79
A Victory is a Victory...by any means, so well done... ![]() But i'm surprised, the 1/2'' drive (if accessible and usable) should provide all the 'purchase' you need to undo the Filler Plugs. Was the problem with using the 1/2'' Drive or Thread...or both... ![]() It looks like you have welded a stud in place, and now out, will no doubt swap in new Plugs... Just Curious... ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
It's mixture of both tbh
Here's the better side of the two ![]() Click image to enlarge The swivel ball isn't coming off either. |
Hello Cactus79
![]() ![]() Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
Defender passed the MOT on Monday, it's all back together for a day and now the headlights have stopped working probably due to the new Osram nightbreakers i put in whilst it was off the road. Looks like it's the dim dip relay behind the dash. New relay ordered.
I still think the MUD LED interior light is one of the best things i've bought for this defender, so dam bright. |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 1000 ![]() ![]() ![]() |
FWIW... I am always very thankful to my 110s previous owners who cared well for my beloved Defender. My wheel bearing blew while out on the trails last weekend and everything came apart super easy. Not too shabby for 18 year old workhorse CSW.
Wow, the hub looks new! ![]() Click image to enlarge Stub is not worn... ![]() Click image to enlarge Yuck,... kaboom! ![]() Click image to enlarge Parts is parts... what a mess ![]() Click image to enlarge Races both inner and outer were scored and the inner was heated a bit... ![]() Click image to enlarge Drifting the new races into place ![]() Click image to enlarge Circlip, spacer ring and hub flange bolts fit just like new, they slipped into place with no problems. ![]() Click image to enlarge Refill the swivel with the one shot ![]() Click image to enlarge Back on the road. ![]() Click image to enlarge 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Must be the season for this... new swivel ball due to corrosion and a nasty grease/oil leak on my 2003 TD5. Wouldnt pass the Dutch MOT due to the leak onto the brake disk.
Pulled the swivel to replace the seal....and found things to be very expensive so far. Waiting for my big package from Paddocks....... Patrick ![]() Click image to enlarge |
I just had to adjust my left front and right rear wheelbearings and replaced the left rear bearings and seal. As I still had bearings spare and I just needed the seal I went to the local official Land Rover dealer and just had to pay €5,- for the seal. I am sure I would be able to find it cheaper but not including shipping.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
Lol at finding things in the hub very expensive! Other than the workshop manual, is there a good guide to follow for rebuilding the hubs? Specifically the oil seal on later type hubs as I think my axle oil is contaminated with the one shot grease. 2014 Keswick Utility 2.2 |
There is a good 12 part series for rebuilding the hub\swivel on YouTube series sponsored by paddocks on YouTube
I think it is called the art of Land Rover maintenance. Patrick |
