Home > Maintenance & Modifications > Thinnest 36 spline quick release steering wheel boss
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Im after a quick release boss and a new wheel for my car as mine is a bit worn and i'd like the extra layer of security having a removable wheel.
Ive done a quick search on here and found info about an fcx boss and a twisted one which everyone said are the thinnest however i think these products may have been discontinued as i cannot find either. Sad
Any help out there?
Post #654368 2nd Oct 2017 4:54pm
X4SKP
Hello LandymanStefan
I have the SnapOff Mechanism from (X D2N Site Supporter) FCX...
It is 27.6mm thick, (Swedish Made), I have now done over 15K Miles with it fitted and have attached / unattached it countless times (certainly hundreds) and it's faultless, really well made, tapered hardened pins...effectively zero movement (play) when engauged...absolutely one of my best mod's... (if not the first I do, if I started again).
You are right, they look to be somewhat 'illusive' in the UK now.
Still for sale in the US at various sites.
Amazon (US)
https://www.amazon.com/Tekniq-Snap-Off-Ste...B006R1X4VS
Maybe try contacting SnapOff directly (often listed including the name Tekniq)
http://snapoff.com/racing/
Just to add this is the Quick Release Mechanism...that attaches to a Boss that is either 36 or 48 Spline
depending on Defender...
Good Luck... Thumbs Up SKIP
Post #654376 2nd Oct 2017 5:26pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Or there is the Optimill version which doesn't need a seperate boss, you just buy the correct one for the number of splines you have and bolt your choice of MOMO or similar wheel to it.
There is talk of an adaptor for the Startech and similar wheels which have a different PCD on the bolt holes if that is what you want.
This is my Optimill boss with MOMO Tuner.
This combination puts the rim of the steering wheel in about the same position distance wise from the indicator stalk etc as the original wheel. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #654409 2nd Oct 2017 7:29pm
The Optimill is the thinnest COTS product by a considerable margin.
Post #654429 2nd Oct 2017 8:40pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
I have a Optimill and I found it perfect fit for my 90 also I have the cone fitted, quick to remove and refit.Here's mine with a Momo 78
The smaller 350mm wheel give a bit more room in the cab and a sportier feel
Post #654432 2nd Oct 2017 8:57pm
JOW240725
Legin, you need some black leather dash parts with yellow stitching. Whistle James
Instagram @suffolk_rovers
Post #654433 2nd Oct 2017 9:02pm
legin
I do need help with the yellow trim I'm just not to sure on one hand it brightens up a very dark dash on the other it does look like a tarts car Rolling with laughter
Post #654437 2nd Oct 2017 9:10pm
JOW240725
Well if the name fits... Rolling with laughter Bow down Maybe yellow leather with a black stitch then Whistle James
Post #654442 2nd Oct 2017 9:28pm
legin
Now you are talking ,shiny yellow PVC better than common leather Laughing
Post #654448 2nd Oct 2017 9:44pm
LandymanStefan
Ive got my momo tuner wheel and im just waiting for my boss to arrive but unfortunately they had none in stock. Hopefully it will arrive next week! Can you change the optimill logo in the middle for a land rover one with one of the retrofit momo horn buttons or is it fixed/different size?
Post #658723 21st Oct 2017 10:57am
legin
I could not change mine so I stuck the Momo centre cap on with double sided tape ,looks all right can't think any other way.
Post #658783 21st Oct 2017 6:24pm
gilarion
A quick tip no matter what boss you use.
Gently bend the stalks towards the steering wheel, a little at a time and even small hands will be able to reach the controls while still holding the steering wheel. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #658792 21st Oct 2017 7:17pm
legin
Best to use a flat ring spanner ,slide the ring part of the spanner over the controls to the tube part half way down just start slowly bending by pulling the spanner towards you, hold the stalk at the steering column end and you get a nice clean bend ,Remember slow and keep checking ! unbending is hard Big Cry
Post #658802 21st Oct 2017 7:53pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
“Gently bend the stalks towards the steering wheel”
I thought I would have to do this, but no problems reaching them using the Optimill boss on my 90.
Post #658831 21st Oct 2017 9:00pm
Gerry
I heard the quick release steering wheel is an MOT failure, is that true?
Post #895409 1st Apr 2021 6:07pm
