Home > Puma (Tdci) > 2.2 Genuine door seal leak
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
My 2012 2.2 drivers door has been leaking since I bought the car earlier last year.
The seal it came with was an aftermarket one so I always put the leaking down to this. Last week I finally got round to buying and fitting a genuine seal for £65 Shocked but its still not water tight - when I took it for a wash this morning there's multiple places where water comes rushing through (passenger side is completely fine)
I'm at a loss of what more I can do to make it water tight. Perhaps I fitted the seal incorrectly, although it didn't seem so technical while I was doing it
Any help much appreciated Thumbs Up
Post #650024 13th Sep 2017 10:02am
dorsetsmith
land rovers water leak see below link
https://1drv.ms/b/s!AtZSoWFHDgnGhERwdB-0XcdTS_UI
Post #650028 13th Sep 2017 10:19am
deaallen
Thanks for that but I had a look and I think its because my door isn't aligned property.
While driving down the motorway I could hear air passing through the top of the door, I pulled over and slammed the door shut and it was a lot quieter and I couldn't feel any fresh air entering.
Its annoying though, the passenger door is perfect, but the drivers (mine) needs a huge slam Sad
Post #651723 21st Sep 2017 10:20am
zsd-puma
It might just need the top bending in a bit or adjust the striker plate in a little if the bottom is out too.
Post #651746 21st Sep 2017 11:38am
deaallen
I read that the strikers can cause this problem if the plastic sleeve is worn, so that was a perfect excuse to buy the x-trouser strikers that I've had my eyes on anyway. If they don't help then I'll give bending the top a try Thumbs Up
Post #651749 21st Sep 2017 11:43am
Smithy
I had the same problem and cured by putting sealing tape 16mm wide 5mm thick around the door.
This black single sided tape is available on EBay in various sizes.
Post #651846 21st Sep 2017 4:35pm
Fat Cog
All of my Defenders have had terrible alignment, in fact my last of the line 2016 90 has door alignment which would make a Morris Marina look over-engineered!
Door leaks, bad alignment...all normal...sad really.
The best cure Ive found is to wipe Vaseline on the seals which makes a bit of a mess but works a treat. Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #651865 21st Sep 2017 5:32pm
newhue
Australia
yep, comes standard really. I can see sunlight flicker through various points in the seals as the car moves about. The upper rear on my drivers gets wind through at various times, the wife has said the same on the passengers. At 160K I have had the rear passenger start squeaking. Figured its not old rubbers old as none of the other doors do it, the rubber was still in great shape also. But fiddle with the strikers, apply rubber grease, graphite powder, or cut a line in the rubber, or remove the welded corner in the seam all to no avail. Piece of Censored still squeaks, sometimes loud, sometimes quiet, sometimes not at all. The joy of Land Rover if you call it that. Live with it or sell it...... My Defender and travels
Post #654175 1st Oct 2017 6:55pm
newhue
Australia
Post #654176 1st Oct 2017 6:56pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
If you think Defenders leak water in the cab, try a Morgan, every trip in the rain you get a free shower Rolling Eyes
Post #654299 2nd Oct 2017 10:11am
