![]() | Home > Puma (Tdci) > 2.2 Genuine door seal leak |
land rovers water leak see below link
https://1drv.ms/b/s!AtZSoWFHDgnGhERwdB-0XcdTS_UI |
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 267 ![]() ![]() ![]() |
Thanks for that but I had a look and I think its because my door isn't aligned property.
While driving down the motorway I could hear air passing through the top of the door, I pulled over and slammed the door shut and it was a lot quieter and I couldn't feel any fresh air entering. Its annoying though, the passenger door is perfect, but the drivers (mine) needs a huge slam ![]() |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
It might just need the top bending in a bit or adjust the striker plate in a little if the bottom is out too.
I read that the strikers can cause this problem if the plastic sleeve is worn, so that was a perfect excuse to buy the x-trouser strikers that I've had my eyes on anyway. If they don't help then I'll give bending the top a try
Smithy Member Since: 25 Jul 2010 Location: Monmouthshire Posts: 21 ![]() |
I had the same problem and cured by putting sealing tape 16mm wide 5mm thick around the door.
This black single sided tape is available on EBay in various sizes. |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
All of my Defenders have had terrible alignment, in fact my last of the line 2016 90 has door alignment which would make a Morris Marina look over-engineered!
Door leaks, bad alignment...all normal...sad really. The best cure Ive found is to wipe Vaseline on the seals which makes a bit of a mess but works a treat. Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 ![]() ![]() |
yep, comes standard really. I can see sunlight flicker through various points in the seals as the car moves about. The upper rear on my drivers gets wind through at various times, the wife has said the same on the passengers. At 160K I have had the rear passenger start squeaking. Figured its not old rubbers old as none of the other doors do it, the rubber was still in great shape also. But fiddle with the strikers, apply rubber grease, graphite powder, or cut a line in the rubber, or remove the welded corner in the seam all to no avail. Piece of
![]() Last edited by newhue on 1st Oct 2017 6:59pm. Edited 1 time in total |
double post My Defender and travels
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
If you think Defenders leak water in the cab, try a Morgan, every trip in the rain you get a free shower
