![]() | Home > Maintenance & Modifications > Rusty Hub Nuts - Best solution?? |
Seapod Member Since: 15 Sep 2016 Location: Devon Posts: 46 ![]() ![]() ![]() |
I fitted my new wheels a month or so ago, there is no centre cap with Bowlers. The existing hub nuts looked to be very lightly/thinly painted. Sure enough a few weeks later they look very mank. Any suggestions as to the best paint/process of sorting them out ?
Here is a pic. ![]() Click image to enlarge ![]() Click image to enlarge My Defender: http://www.defender2.net/forum/post630322.html#630322 |
A bit of ACF 50 is a quick and easy fix. Failing that, take them out and prep and paint as with any steel but make sure that they're properly dry before re-fitting or the socket will take the paint off again. Darren
Thanks Both
Blackwolf, I am going to go with your suggestion about changing the bolts, I see exactly what you mean about potential wheel damage when studying the photos. I will take the wheels off and give the whole hub a clean, corrosion treatment and paint. Cheers SP My Defender: http://www.defender2.net/forum/post630322.html#630322 |
Black wolf - would these be acceptable? As far as I can tell they meet the requirements for 10.9 or greater strength. https://www.accu.co.uk/en/cap-head-screws/16142-SSC-M10-45-12-9 I feel like I need a second opinion on something as critical as the fasteners that connect the wheels to my vehicle! My Defender: http://www.defender2.net/forum/post630322.html#630322 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17941 ![]() ![]() ![]() |
I would have thought so, although it is a slightly wierd webpage. The HT grade 10.9 is what you need, it is unusual for HT bolts to be described as "hardened", which causes me a little unease. Also the picture is a computer generated graphic and not a photo, so it is impossible to tell if they look like normal bolts (ie, rolled threads not machine cut threads, knurled surface to the head, etc.)
I am also amazed at the number of manufacturers quoting DIN912 for these, since this has been superseded. DIN912 as far as I know only defined the standard dimensions. So, I think that these are probably normal M10x45 grade 10.9 hex socket head bolts, which is what you need, but without seeing one in the flesh as it were, I cannot give you a definitive answer. ![]() I simply visited my local fastener dealer and asked for some, available off the shelf at a very modest cost. |
Thanks again BlackWolf, I have ordered the various bits and pieces and will let you know how I get on My Defender: http://www.defender2.net/forum/post630322.html#630322
Hi all & especially Blackwolf.
Right, finally on the case with this. Shooting practice this morning meant that I didn't get started until 1600 today. A top tip from a mechanic friend was to get a blowtorch onto the hub nuts before attempting to remove. No need to get them glowing, but enough to soften the copious amounts of factory loc tite. He was speaking from hard won experience, having sheared a number of the very same bolts. Anyway, having pilfered SWMBO cook's blow torch from the kitchen drawer (a high risk strategy!) I gave them about a 45 sec blast and they came off with some hard graft but nothing too extreme. An hour or so later, all ten hex bolts are now out. Unfortunately my crap chinese 8mm socket head 1/2" drive snapped as I was torqueing it to 48lb. Lesson (and excuse!) get some decent socket sets. Here are some half-way pics, will resume tomorrow following a trip to halfords etc ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge My Defender: http://www.defender2.net/forum/post630322.html#630322 |
Prepped for spraying, I used Rustoleum CombiColour Black gloss straight to metal paint as have been pleased with it in the past.
![]() Click image to enlarge And then back together ![]() Click image to enlarge My Defender: http://www.defender2.net/forum/post630322.html#630322 |
One of those satisfyingly simple jobs that makes a difference and fractionally improves the overall quality of the wagon.
Before: ![]() Click image to enlarge After ![]() Click image to enlarge ![]() Click image to enlarge Thanks to all for your tips and advice, especially Blackwolf for the suggestion of the hex head bolts to avoid damage to the wheels in the future My Defender: http://www.defender2.net/forum/post630322.html#630322 |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
looks loads better DEFENDER 90 TDCI XS,
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
