| Lotus_esprit_s1
 | If it’s an elderly 300tdi water most likely being drawn in through cracks in the gutter sealant the length on the roof and running down internally to the front of the vehicle above the doors. Only way to properly fix it is to rake out all the sealant and reapply - last one I did I used Soudal carbond about five years ago and still no water ingress. Sikaflex is no good if you want to paint the roof. |
                |  30th Sep 2017 5:31am |  |
                | zsd-puma
     | Quote:Sikaflex is no good if you want to paint the roof.
 It depends which Sikaflex you use. Sikaflex do purpose made car body sealants which are over paintable.
                |  30th Sep 2017 9:25am |  |
