Home > Td5 > Hub mess
Page 1 of 3 123>
Cactus79
Hub mess
Took the cover off as needed to replace the discs for the MoT to be met with this
Suggestions?
I'm at the point of cutting through the flange / CV with an angle grinder..
Post #653350 28th Sep 2017 10:44am
geobloke
Good grief... Shocked Shocked looks like it has been welded...
To begin with try some heat and the LR special Tool No.1 (lump hammer) to see if you can free up the hub.
Is that the front or rear hub? If rear you should be able to pull out the hub and half shaft together as one. This is obviously not possible with the front CV/shaft assembly.
Post #653355 28th Sep 2017 11:14am
X4SKP
Hello Cactus79
Shocked WOW...The Drive Flange and Shaft look to be in a 'well advanced stage of corrosion'... Exclamation
I would first try a combination of heat and 'light impact' both in line with the Drive Shaft and rotational to try and free up the apparently 'fused' state of the Flange...to hopefully allow the Drive Flange to be withdrawn.
Both Drive Flange and Shaft look to need replacing (just this corner or is this typical... Question )
If you can free the Flange just enough you may be able to get behind it with some sort of extractor...
If this is at the rear then both the Flange and Drive Shaft could be extracted 'as one'...
Not the same but this was to remove the Hub / Disc assembly (Front)...when the Drive Flange had been removed.
That Angle Grinder may be needed yet, and that commits you (more or less) to a full strip down and and parts replacement, Drive Shafts, Flanges, Seals, and probably Bearing too as you have gone that far...
Good Luck...(oh and try and get some Plusgas in there...anywhere will help...) SKIP
Post #653356 28th Sep 2017 11:15am
That's been welded.
If it is the front, you have no option but to cut the weld off with a grinder or cutting disc. You'll need a new flange and CV joint to reassemble plus sundry parts like the circlip.
If it is the rear, the flange and halfshaft should come out welded together, and functionally will be little different to the single-piece halfshafts used on the runout models. At the rear, you could simply reuse the welded assembly, or you can replace with new halfshafts and flanges.
Post #653378 28th Sep 2017 12:19pm
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
Both mine were like that, had to have them cut off , lots of new bits. Crying or Very sad
Post #653382 28th Sep 2017 12:38pm
Cactus79
It's the front, haven't looked at the rears although i'm going to have to after this.
Other side isn't as bad but it's still not pretty, still likely to have a chance of removal though.
Have ordered new CV / Flanges for both sides, swivel rebuild kits, bearings and a few other bits.
i'll have missed some stuff but won't know the state until it comes apart and i can reassess.
Atleast i'm not alone and someone elses needed cutting off.
Post #653392 28th Sep 2017 1:09pm
lightning
Can't you just pull the drive member off together with the drive shaft (which should just slide out) then replace both?
Post #653394 28th Sep 2017 1:47pm
It's the front axle, so the shaft has the CV on the inboard end. Sad
Post #653395 28th Sep 2017 1:49pm
X4SKP
blackwolf wrote:
That's been welded.
Censored I think you are right...now I look again...(my brain just didn't go there... Exclamation)
Well that's one way to 'take up' the play, on Drive Shafts...i'd be checking there wasn't
sawdust in the Axles too faced with that.
Good Luck Catus79...looks like you're tackling this one head on now...Angle Grinder it is... Shocked SKIP
Post #653396 28th Sep 2017 1:55pm
williamthedog
One more reason to take off your drive flanges and grease them, only takes 20 minutes to do and saves a lot of grief later on.
Post #653402 28th Sep 2017 2:36pm
Cactus79
First half of the battle won, drive flange is off, luckily it wasn't welded. Resorted to 1mm cutting disc on the grinder.
Now whats the betting the nut behind is going to be equally stubborn?
Post #653466 28th Sep 2017 7:11pm
Wow, I am surprised!
I have never seen an un-welded one that has looked so welded!
Still, that is good news, your vehicle may just be suffering from neglect rather than butchery.
Post #653477 28th Sep 2017 7:59pm
X4SKP
Cactus79 wrote:
....drive flange is off, luckily it wasn't welded...
Good Man... Thumbs Up (press on and grease up... Exclamation ) SKIP
Post #653478 28th Sep 2017 8:01pm
lightning
I checked mine a couple of months ago. One rear had a cap full of powder so needed a new driveshaft and drive member, the other needed a drive member, both front splines were dry but serviceable.
None of them were near to failure though.
Post #653507 28th Sep 2017 9:14pm
DieselBeast
1998 Defender 90 300 Tdi PU Java Black
I imagine one previous owner lost the circlip and had a welder to hand.
And then I just read not welded Whistle
Post #653554 29th Sep 2017 7:26am
Page 1 of 3 123>
