Home > Maintenance & Modifications > Which sound proofing? |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
I was wondering what you guys would recommend?
The prices vary wildly on ebay, dynamat seems good but im wondering if it's overpriced as it's endorsed by Chip Foose... I'm going to be following a similar fitout to this, but less extensive: http://www.defender2.net/forum/topic19837....+deadening 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
26th Sep 2017 11:22am |
Chris90V8 Member Since: 02 Oct 2016 Location: Suffolk Posts: 714 |
Sitting on the sidelines watching this one 🚜. ...... . .... . .. 🚗🚐🚛🚚🚚🚗🚙🚐
26th Sep 2017 11:25am |
#canofworms? 1993 200 Tdi 90 CSW
26th Sep 2017 11:28am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2077 |
Try Fatmat instead, very similar to Dynamat but cheaper and the quality seems identical as does performance. Did both my 90 and 110 with it, no issues what so ever to report.
It sat in my 90 for 3 years and going on a year in my 110. Definitely makes a big difference However its best when used with multiple layers of closed cell foam* where ever you can fit it really! Then a final layer of carpet/rubber trim on top. *When sticking down use a high temp heavy duty spray glue, not the self adhesive foam, slight bit of heat and it comes away... |
26th Sep 2017 11:30am |
I've used Silent Coat products on mine - both the damping mats and the foam isolator - and I'm really pleased with the result. I haven't finished yet as I've still got the front floor and seat box to do, but I've completed the rear tub and roof and it's transformed it from a noise level perspective.
Click image to enlarge Click image to enlarge Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
26th Sep 2017 11:31am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3696 |
Hello
I uses silent coat with a 8MM soft cell foam over the top also. Seems very good and for product seems the best Click image to enlarge Click image to enlarge https://www.deadening.co.uk/collections/cld-sound-deadening-mats Biggest gains I found were doors as it sound less like a tin can rattling when you shut and all over seat box and inside the battery and cubby box. Watch this short clip... sort of sells itself |
26th Sep 2017 11:33am |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 311 |
Fatmat is a good cheaper alternative to dynamat, I found however that I had to double the layers of fatmat, so the cost savings are negligible.
Fatmat also doesn't seem to hold as well as Dynamat I would advise not to use on the roof that's for sure as it will begin to peel off. |
26th Sep 2017 11:35am |
Is this a good deal: http://www.ebay.co.uk/itm/Silent-Coat-2mm-...Sw241YmyaU
I just want to get rid of the vibration for now, maybe at a later date i'll try the foam 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
26th Sep 2017 12:07pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
I stripped out loads of Noise Killer ~6mm matting from the floor of mine because the foam inner was acting like a sponge and holding water. I've replaced it with 2mm unbranded Dynamat/Silentcoat type stuff from eBay which seems good for sound deadening but not as good at noise reduction. Maybe it needs another layer or a high density closed cell foam overlay? The effectiveness of a big mid-panel pad of the 2mm stuff on the door skins makes it worthwhile going to the trouble of removing the door card and plastic liner.
26th Sep 2017 3:36pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19609 |
Dynamat. Fit cheap stuff to a cheap car, Defender deserves quality. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
26th Sep 2017 3:38pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Silent coat here, just as good as dynamat but noticeably cheaper!
26th Sep 2017 4:08pm |
The only bit of my car (a 110)
I have not done is the roof... (oon and engine bay) Are these two worth doing? Thanks |
26th Sep 2017 4:16pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5765 |
Did a full Silent Coat DIY on a 110 SW 7-seater last year. Easy to use, just time consuming. Fantastic results, especially with carpets back on top. Used Colin at the Sound Deadening Shop. Usually does a discount for Def2 members. Also very efficient delivery and helpful with any questions. Recommended. Here's what I used:
Silent Coat 2mm Mat, Silent Coat Isolator 6mm and Dodo Pro Barrier MLV. Going to do my DCPU in the next week or so and whilst I was thorough on the SW looking to do even more on the DCPU including adding Isolator to the interior of the door cards, potentially unscrewing the floor plates and adding Isolator underneath, and (depending on advice from the forum) would take the dash off if worth it and there are places to be tackled. Finally will add an acoustic engine blanket, bonnet sound barrier and gearbox tunnel blanket: https://www.nkgroup.co.uk/product/vehicle-...-blankets/ https://www.nkgroup.co.uk/product/land-rov...g-blanket/ https://www.nkgroup.co.uk/product/land-rover-under-bonnets/ Good luck, takes time but it's worth the effort Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
26th Sep 2017 7:04pm |
"Finally will add an acoustic engine blanket, bonnet sound barrier and gearbox tunnel blanket"
Any side effects with the use of the blankets? I.E...poor heat dissipation? 🚜. ...... . .... . .. 🚗🚐🚛🚚🚚🚗🚙🚐 |
26th Sep 2017 7:59pm |
