![]() | Home > Maintenance & Modifications > Widespread DPF removal fraud on EU wide level |
| Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696
This isn't an argument Dave, and I am not trying to make it into one.
My vehicle is of a size and shape that suits my needs. It is operating as the manufacturer intended, and meets the emissions standards of an EU4 class engine. A Defender with an EU4 engine with the CAT and DPF removed will emit more. Yes I am sure there are other cars that could emit less but that's hardly the point. My personal choice of vehicle is irrelevant in this case. My choice of driving a Defender is 100% legal and compliant with emissions regulations, just as other people's choices to remove those devices is not. By removing a DPF / CAT you are modifying the emissions system in such a way as to make it pollute more than was intended when it was originally built to whichever classification. Are you telling me that these measures increase pollution? Your solution is (obviously) unworkable. I don't have, and i'm sure there doesn't exist a "perfect" solution, but this is the one that the industry, government and researchers have come up with. |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Just a little note about why I posted this. The posted news topic highlights the fact that there seemingly are numerous problems with DPF as installed on all EU5 and later diesel cars. I have not seen much reported about this before yesterday's piece, but the number of issues seems to indicate that governments/EU have put a frequent and expensive problem in new car drivers hands. Given that there seemingly is an entire European fraudulous industry to take care of cars with DPF problems without a very expensive replacement is sufficient indication of the size of the problem. It seems like the entire DPF should get a serious rethink.
Oh, and EU4 cars, including the pre 2011 Puma 2.4 engines do not have a DPF, only a CAT. Our Aussie friends down under also don't have this problem. I believe all Pumas including the most recent 2.2 remained EU4 and thus DPF-less until the very end. Good for them. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3667
CAT's DPF's all seem to be drip trays to solve an oil leak rather than a 'new oil seal'?? If you see what I mean
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
Really it's down to the manuafacturers marketing and governements drive for diesel. Dealers were often selling people diesel cars even though a petrol would be more suitable for their needs. On the other hand many people were walking into dealerships and saying they want a diesel, they wouldn't even consider anything else even if the dealer advised them to buy a petrol engine. |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
or soft ware frig
Well done - you are quite correct Eric. My intention was to indicate any emissions-control device that could be simply bypassed. |
Agreed but I think "Government" is changing its tune now. Consumers need the correct, unbiased information to be available with which to make a logical choice for their needs. Then if they still buy a diesel irrespective of logic then they have to endure the consequences of the additional emissions equipment they need to maintain. The information needs to come from an unbiased source, not the PR machine of a manufacturer. |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
I believe under the Road Traffic Act (I may get the wording wrong). " It is an offence to supply, fit or use a defective item on a vehicle" Now the argument could be what constitutes "defective" A tyre with less then 1.6mm tread is defective as it is below the legal minimum. An exhaust pipe with a dummy cat in on a vehicle fitted with a cat must be defective by definition? Any item which by law must be type approved which does not have a valid type approval must be defective by definition. Any item which is type approved by the manufacturer and is then subsequently modified without the manufacturers consent must be defective as the type approval no longer applies! Please learn what a type approval looks like! An E + a number in a circle is not an E mark! The E mark constitutes 3 parts, the regulation or amendment, the country which has done the approval, and the actual approval number. Unfortunately there are either unscrupulous or ignorant suppliers who are breaking the law by selling illegal parts often to unsuspecting customers. Ignorance is no excuse in the eyes of the law. Illegal parts on a vehicle and your motor insurance can be declared void! Brendan |
Nicely put Brendan
But you quote "It is an offence to supply, fit or use a defective item on a vehicle" Haven't Land Rover been getting away with that for years?? Hijacks the post for cheap laughs. Sorry, I'll get me coat then....... |
| rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945
DVSA starting to get tough?
https://mattersoftesting.blog.gov.uk/diese...integrity/ |
An interesting read
Brendan |
Disabling factory fitted emissions control systems or otherwise making the vehicle non-compliant with the emissions standards it was originally built to meet is an offence under Construction and use regs. Unless it was a Diesel built before 1973.
Even the boy racers who put those little filters on their crank case breathers instead of feeding them into the inlet are breaking the law if the car was made after 1972. |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
^^ so you are saying that all those ”provent” modifications are illegal?
I think the provent things are effectively like oil catch cans, so they don't just vent the crank case fumes to the atmosphere. But the cheap filters people put on their 1ltr hatchbacks most definitely do, as they spread oil vapour all over the engine bay.
I think the crankcase vent rules only apply to spark ignition engines not diesels anyway. |
