Home > Maintenance & Modifications > Battery earth connector
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Finally got round to wiring the winch everything went ok, but when i came to put the earth to the battery ???? how have you Guys connected the earth to the battery terminal ? do you need to buy a different battery terminal as i can't figure out how to connect the earth...any pics or advice Guys NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65258 27th Mar 2011 6:07pm
mse
I used the main chassis connector 1st point from the battery Mike
Post #65267 27th Mar 2011 7:12pm
fekete
Cheers Mike i was thinking that but not sure as it says connect straight to battery Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65269 27th Mar 2011 7:31pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Grind down an ordinary bolt (longer) so the head fits as per the original. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #65271 27th Mar 2011 7:44pm
fekete
Thanks willy thats the one Bow down Bow down NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65273 27th Mar 2011 7:51pm
leeds
Or buy a battery terminal clamp which has an 8mm stud. You can attach about 4 35mm2 cables to it.
However as it sticks upwards insulate the underneath of the lid or use a rubber cover
Something like this
Cost about �3 each
HTH
Brendan
Post #65280 27th Mar 2011 8:15pm
fekete
Thanks Brendan, i'm going to go with willys way Thumbs Up The cables you supplied are great will be in touch next week as its the lights next and need a few bits Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65282 27th Mar 2011 8:19pm
leeds
No problem Karl. Just give us a shout when you are ready and I try and help out.
Brendan
Post #65290 27th Mar 2011 8:39pm
