![]() | Home > Maintenance & Modifications > Battery earth connector |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5111 ![]() ![]() ![]() |
I used the main chassis connector 1st point from the battery Mike
Cheers Mike i was thinking that but not sure as it says connect straight to battery
Grind down an ordinary bolt (longer) so the head fits as per the original. Original Member Pie n Pea Club.
110 HCPU Tipper Last edited by willy eckerslike on 27th Mar 2011 8:04pm. Edited 1 time in total |
Thanks willy thats the one
Or buy a battery terminal clamp which has an 8mm stud. You can attach about 4 35mm2 cables to it.
However as it sticks upwards insulate the underneath of the lid or use a rubber cover Something like this ![]() Cost about �3 each HTH Brendan |
Thanks Brendan, i'm going to go with willys way
No problem Karl. Just give us a shout when you are ready and I try and help out.
Brendan |
