![]() | Home > Puma (Tdci) > Leaking on pasenger floor |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
Heater vent is on the same side wether it is RHD or LHD.
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
remove the intake vent on the wing top, put your hand in, it will prob be full of water at bottom near the back you'll feel a rubber teet in the base push a finger through to clear it out,there is a seocnd teet in the round part of the blower box.
hope this fix's it for you 1968 1/32 scale Britains 109 Pick up. |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
Mine it was very much the seal between heater box and seat box water was running down the bulkhead and in
You may also want them to replace the bits rusting under there aswell! Mike |
| defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219
Cleaned my top teet. I need to see if that does it.
Thanks for the info so far. |
| gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107
My old Td5 leaked through the seal under the bulkhead to screen bracket cover (if that's an adequate description of it). Was coming through the bolt-holes and running down the inside of the dash then appearing as an accident in the foot-well in surprising quantities...fixed under warranty (but had it been out of warranty I'm sure some clear sealant would have done the trick) 1953 80
1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
| All times are GMT |
