![]() | Home > Puma (Tdci) > Leaking on pasenger floor |
| 110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444
Is that the Holy Grail I can see in one of those pictures? Oh no. Just my imagination
Water ingress farce manual on Google. Have you heard the one about the Mitsubishi and Land Rover air-con and the cat? Sorry for the weirdness, but I've given up on this one! Winscreen seal, aircon system, roof condensation, door seals, windscreen hinge bolts... |
| defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219
I have seen egress manual and if this wasn't a puma I would look for the obvious places. I mean it could be coming from the door seal and traveling over the top of the kick panel and running down. I have seen water do worse in rain. I need to take a hose to it. The interior light plunger screws are all rusted as well.
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
check the drain teets in the blower box these often get clogged up 2.4 90 XS
Do you have pics of what they are? I have never seen them before. How do I clean them. Thanks |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
From the pictures it looks like mine when it was leaking badly.
The foam seal between the bulkhead and windscreen had to be replaced by the dealer. It fixed that leak and all I have to do now is stop the leak on the passenger door seal - new door rubber has not sorted it ! Bob |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
When mine did this they removed the wing, removed the heaterbox resealed and refitted...it leaked in exactly the same place and they had tried the other things first (just to waste my life) Mike
It is amazing that it leaks. I don't think it is coming through the seal for the windshield to heaterbox but who knows. It could be the door seal but am not sure. I would like to see the drain holes I should check if anyone has a picture.
thanks |
THere isnt a seal between heaterbox to windscreen Whilst the door seal could be the problem (possibly look for kinks and where the heater routes) - i doubt its that Mike |
I meant bulkhead to windscreen. I miss the old style heaterbox you could see if there was a leak. IN the puma I have no clue what is under the hood and don't have a dealer I am close to.
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
Your not on your own mine needs a new bulk head
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
Earlier thread had these pictures showing the Heater box drain holes"-
http://www.defender2.net/forum/topic5842.html |
You really need a new bulkhead? Come on. Clearly same leak though Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Looking at that other thread what do you clean the teets out with?
Does it matter as far as orientation my truck is lhd? |
you could be right... Ive been waiting 12 months for this as the dealer has not sorted out the body shop ?
