Home > Maintenance & Modifications > Ready for bead blasting and anodising....
Page 2 of 2 <12
rallysteve
As adverse as I am to using steel or stainless grub screws into aluminium it might be suitable for this application. Thinking back to certain mountain bike pedals they have a similar arrangement with a grease port normally sealed with a grub screw (into an aluminium or magnesium alloy housing) with grease being administered by syringe.
The clearances on the pin in this case may prohibit the use of a high viscosity grease however a lighter machine oil could be administered in the same way?
Cheers,
Post #646246 25th Aug 2017 11:52am
Huttopia
Good shout, I know the pedals you mean!
Post #646263 25th Aug 2017 1:43pm
grafty99
There is always the option of using a chainsaw grease gun to lubricate if the hole is large enough (2-3mm) Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #646447 26th Aug 2017 4:59pm
Huttopia
In each pic the image on the left is the original part, the centre is hard anodised and the right is bead blasted and hard anodised. The bead blasted parts look great, really pleased with the finish.
Slowly getting there.....
Post #652041 22nd Sep 2017 11:17am
Coatesyyy
Looking good! Thumbs Up
Post #652094 22nd Sep 2017 4:12pm
Huttopia
Thanks! I guess the photos aren't the best but they give an idea. I was in Salcombe a few weeks ago and saw a 15 plate 90 with dreadful blistering on the bonnet blocks - they were really poor. Hopefully these will solve that problem!
Post #652105 22nd Sep 2017 4:37pm
Page 2 of 2 <12
