Home > Maintenance & Modifications > Ready for bead blasting and anodising....
Huttopia
It has taken a while but here are the first samples ready to go for bead blasting and anodising next week. Really looking forward to getting them back and seeing the finish. We will then carry on with the hinges, door handles and infamous windscreen squirter!
Post #643513 12th Aug 2017 8:39pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
They will have a better "key" than when standard so when finished they should last for years Thumbs Up
Post #643522 12th Aug 2017 9:35pm
Huttopia
Thumbs Up that's the plan.
Post #643579 13th Aug 2017 9:33am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
They look pretty impressive already Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #643581 13th Aug 2017 9:46am
Huttopia
I know how much they will cost finished i.e. unpainted. What is a reasonable sale price for a pair?
Post #643587 13th Aug 2017 10:35am
Rosco
Difficult one to answer.
A quick google shows the current versions are priced from £72 to £119 2007 - Stornoway Grey 90 XS SW - Gone
Post #643590 13th Aug 2017 10:54am
Huttopia
Thanks Rosco. It probably makes sense to send the samples to a distributor or two for them to assess the quality and determine a sensible price point in the market.
Post #643929 14th Aug 2017 7:05pm
Huttopia
Better image. Original part at the top.
Post #645882 23rd Aug 2017 3:41pm
Huttopia
Hinges - how about a small hole to enable some lubrication?
Post #645883 23rd Aug 2017 3:47pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Yep that sounds like a great idea, I would definitely be interested in a set if you go into production since the replacement ones I bought aren't very good quality. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #645885 23rd Aug 2017 3:58pm
L110CDL
Left pic Thumbs Up
Just big enough hole near to the top to take the small pipe from the lubricating can Whistle Clayton.
Keeper.
Post #645973 23rd Aug 2017 10:00pm
Rosco
Would a small hole in three places along the hinge pin be worthwhile? 2007 - Stornoway Grey 90 XS SW - Gone
Post #646230 25th Aug 2017 10:08am
Huttopia
Agreed, the initial drawing is only going to enable lubricant on the middle part, so replicating that top and bottom makes sense. Thanks Rosco!
Post #646232 25th Aug 2017 10:18am
rallysteve
I am presuming the pin is static in the outer lugs of the hinge and the middle part rotates around it. Therefore I cannot see the advantage of lubricating the outer parts.
Would be worth having a grease nipple on the lubrication point to prevent dirt ingress if there is room. If not maybe some other form of cap
Post #646234 25th Aug 2017 10:21am
Huttopia
We looked at a grease nipple but it would mean a quite visible change in appearance and we are trying to keep it all completely standard. I'll revisit it and see whether we could go with a cap of some sort. Thanks.
Post #646236 25th Aug 2017 10:30am
