![]() | Home > Maintenance & Modifications > Ready for bead blasting and anodising.... |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
They will have a better "key" than when standard so when finished they should last for years
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1872 ![]() ![]() ![]() |
They look pretty impressive already
![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
I know how much they will cost finished i.e. unpainted. What is a reasonable sale price for a pair?
Difficult one to answer.
A quick google shows the current versions are priced from £72 to £119 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Thanks Rosco. It probably makes sense to send the samples to a distributor or two for them to assess the quality and determine a sensible price point in the market.
Better image. Original part at the top.
Hinges - how about a small hole to enable some lubrication?
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Yep that sounds like a great idea, I would definitely be interested in a set if you go into production since the replacement ones I bought aren't very good quality. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11049 ![]() ![]() |
Left pic ![]() Just big enough hole near to the top to take the small pipe from the lubricating can ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Would a small hole in three places along the hinge pin be worthwhile? 2007 - Stornoway Grey 90 XS SW - Gone
Agreed, the initial drawing is only going to enable lubricant on the middle part, so replicating that top and bottom makes sense. Thanks Rosco!
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I am presuming the pin is static in the outer lugs of the hinge and the middle part rotates around it. Therefore I cannot see the advantage of lubricating the outer parts.
Would be worth having a grease nipple on the lubrication point to prevent dirt ingress if there is room. If not maybe some other form of cap Steve 02' 110 TD5 Double Cab Rebuild Thread |
We looked at a grease nipple but it would mean a quite visible change in appearance and we are trying to keep it all completely standard. I'll revisit it and see whether we could go with a cap of some sort. Thanks.
