![]() | Home > Maintenance & Modifications > Good brand of EP75w90 |
| sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1248
Opie Oils
Miller Oils Morris Lubricants Plenty of options out there, use all in the past - as long as it meets the correct spec then shouldn't really matter. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
^ and also rock oil
| Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514
Mobilube™ 1 SHC 75W-90
https://www.mobil.com/English-IT/Commercia...-SHC-75W90 Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
This ^^^ Gear oils aren't subjected to the same extreme environment as engine oils (where it may pay to be a bit more picky) and so as long as the spec is correct then it really doesn't matter. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
Comma oil too.
But as above, the transfer box and diffs on Defenders all use pretty basic oils. |
| LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881
This may sound like me being stupid but is that mobilube shc 75w90 the same as ep 75w90
I have some comma mtf75w90 at home but I thought the ep was for extreme pressure and had other properties other than viscosity. Or am I looking into this too much? |
| apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547
Interestingly.. Comma recommend MVMTF Plus 75w-90 for the gearbox and EP80w-90 GL5 for the transfer box. (for a 2.2 DPF and they claim a 100% compatibility guarantee) http://www.commaoil.com/products/results/92085637
Just realised yours is a 2001 TD5 according to your avatar. http://www.commaoil.com/products/results/92085637 they recommend MVMTF Plus 75W-80 for gearbox and EP80W-90 GL4 for the transfer box. Doesn't really help your question, but thought it interesting as you mentioned you had a bottle of Comma MVMTF |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674
Castrol! DEFENDER 90 TDCI XS,
Well I emailed Dave at ashcroft as they know a fair bit about transmissions and he said any ep80 any ep90 and and 75w90 regardless of the prefix. So I think I'll use my existing comma mvmtf 75w90
