Home > Maintenance & Modifications > Good brand of EP75w90
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Just looking to buy some ep75w90 for my lt230 transfer box and can only find carlube or triple qx branded products are these any good or do any of you know where i can pick up something of potentially higher quality.
Post #650870 17th Sep 2017 9:23pm
sako243
Opie Oils
Miller Oils
Morris Lubricants
Plenty of options out there, use all in the past - as long as it meets the correct spec then shouldn't really matter. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #650895 17th Sep 2017 10:45pm
dorsetsmith
^ and also rock oil
Post #650919 18th Sep 2017 7:17am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Mobilube™ 1 SHC 75W-90
https://www.mobil.com/English-IT/Commercia...-SHC-75W90 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #650923 18th Sep 2017 7:59am
This ^^^
Gear oils aren't subjected to the same extreme environment as engine oils (where it may pay to be a bit more picky) and so as long as the spec is correct then it really doesn't matter. Darren
Post #650929 18th Sep 2017 8:30am
zsd-puma
Comma oil too.
But as above, the transfer box and diffs on Defenders all use pretty basic oils.
Post #650930 18th Sep 2017 8:32am
LandymanStefan
This may sound like me being stupid but is that mobilube shc 75w90 the same as ep 75w90
I have some comma mtf75w90 at home but I thought the ep was for extreme pressure and had other properties other than viscosity.
Or am I looking into this too much?
Post #650933 18th Sep 2017 8:53am
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Interestingly.. Comma recommend MVMTF Plus 75w-90 for the gearbox and EP80w-90 GL5 for the transfer box. (for a 2.2 DPF and they claim a 100% compatibility guarantee) http://www.commaoil.com/products/results/92085637
Just realised yours is a 2001 TD5 according to your avatar. http://www.commaoil.com/products/results/92085637
they recommend MVMTF Plus 75W-80 for gearbox and EP80W-90 GL4 for the transfer box.
Doesn't really help your question, but thought it interesting as you mentioned you had a bottle of Comma MVMTF
Post #651177 18th Sep 2017 11:39pm
LR90XS2011
Castrol! DEFENDER 90 TDCI XS,
Post #651196 19th Sep 2017 6:22am
LandymanStefan
Well I emailed Dave at ashcroft as they know a fair bit about transmissions and he said any ep80 any ep90 and and 75w90 regardless of the prefix. So I think I'll use my existing comma mvmtf 75w90
Post #651232 19th Sep 2017 10:29am
