![]() | Home > Maintenance & Modifications > Sealing Tape - egress areas |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Sorry i don't understand your question?
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 ![]() ![]() ![]() |
Body sealing (footwells for example) the water egress reference talks about tape and sealing (flexi joint)
I assume any good brand carboy sealer will work but also looking at automotive flashing materials for example |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
Any car body sealer will do the job -whatever you have available over there. The best type is the non setting stuff, which forms a surface skin but remains flexible. For added strength I have covered re made joints with Duck tape, which is a self adhesive fabric/plastic tape. You may be able to get it where you are - try googling "Duck tape".
Hope this helps |
ahh ok it used to recomend DumDum but it's long longer available.
I got some of this butyl stuff. http://www.ebay.co.uk/itm/DUM-DUM-DUMDUM-M...Sw42dZAd4w |
greenlandrover Member Since: 09 Jul 2017 Location: Stourbridge Posts: 145 ![]() ![]() ![]() |
I got some of this from Frosts
http://www.frost.co.uk/eastwood-flexible-s...ement.html |
