Home > Technical > ECU update
Page 2 of 2 <12
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
OK so today I filled it up and took it for a decent test drive. Mostly on duel A45. Kept to 60mph, drove like a granny and through the gears I did not let it rev over 2500rpm.
The result was 22.38 which has pushed my avarage (over 2826 miles) down to 22.96mpg.
So the new ECU up date does nothing to help, if anything it is worse. Before December with the roof rack on (now off) it would have been plus 27mpg.
Boy
Post #61214 26th Feb 2011 9:13pm
BRDM Driver
Is there a method of finding the ecu software verisons?
Westover in Christchurch told me there were no updates for my 2007 57 plate puma.
Post #64598 21st Mar 2011 8:33pm
The Boy
I don't know how you can tell but I bet soemone like Pete form BAS woudl know.
BTW my fuel problem is now sorted. I put a new MAF in and it is running very well, more to report soon. I will add that it was a pity that the dealers would not fit a new one and stuck to thier story that mine was fine, such liers!!!
Boy
Post #64601 21st Mar 2011 8:43pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Just had my ECU update done.....seems more responsive and has more urge - not sure about MPG just yet. No other difference except that my 'surging' problem when engine cold and pulling up slight incline in 2nd seems to have been reduced. wynnes diesel additive was added too along with 2year service items - so there may be other factors at play here.
Post #64648 21st Mar 2011 11:19pm
mse
Boy
Glad it worked for you Thumbs Up Mike
Post #64667 22nd Mar 2011 8:22am
ickle
Question - I've a scangauge fitted that gives an inlet air temperature reading - is this taken from the MAF sensor, if so if the reading is about ambient air temp, is it safe to assume the MAF is OK?
Thanks
Keith
Post #64804 23rd Mar 2011 12:11am
Page 2 of 2 <12
