![]() | Home > Technical > ECU update |
BRDM Driver Member Since: 10 Mar 2011 Location: dorset Posts: 25 ![]() |
Is there a method of finding the ecu software verisons?
Westover in Christchurch told me there were no updates for my 2007 57 plate puma. |
I don't know how you can tell but I bet soemone like Pete form BAS woudl know.
BTW my fuel problem is now sorted. I put a new MAF in and it is running very well, more to report soon. I will add that it was a pity that the dealers would not fit a new one and stuck to thier story that mine was fine, such liers!!! Boy |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
Just had my ECU update done.....seems more responsive and has more urge - not sure about MPG just yet. No other difference except that my 'surging' problem when engine cold and pulling up slight incline in 2nd seems to have been reduced. wynnes diesel additive was added too along with 2year service items - so there may be other factors at play here.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5106 ![]() ![]() ![]() |
Glad it worked for you ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
Question - I've a scangauge fitted that gives an inlet air temperature reading - is this taken from the MAF sensor, if so if the reading is about ambient air temp, is it safe to assume the MAF is OK?
Thanks Keith |
