![]() | Home > For Sale & Wanted > [For Sale] 110 under-arch fuel tank and Td5 crossmember |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205 ![]() ![]() ![]() |
Photo's as promised.....
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge And the crossmember: ![]() Click image to enlarge |
Rusty marks are just surface rust as it's been shotblasted, so bare metal, and it's been sat in my garage for a while.
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
So the tank fits inside the tub and fills once the main tank is fill. Then slowly drains into the main tank...
Is that correct? It basically takes up the rear corner of the tub... Think it will fit a 130? |
Yes, I think the proper term for them is "fill through", so you stick the pump nozzle in the usual filler, pump away, fuel will flow through the aux tank, then into the main tank... main tank fills to the brim then starts to fill the aux tank.
So, your fuel guage won't move until the aux tank runs empty. I suppose some mileage calculations will need to be worked out so you can tell when the aux tank has emptied. There is a balance pipe than can be fitted (see extra pics below), which is supposed to stop an air lock that can occur; but I've heard that others with a fill through tank don't have them fitted and have no problems. |
![]() Click image to enlarge ![]() Click image to enlarge Finally sussed out how to add photos from my album! |
No idea about the defender but my TD5 Disco gauge would trip out and show empty with full warning light on when both tanks were full, then as the aux tank emptied out it would go mental and finally settle down to full. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
I'm pretty sure defenders just sit at "full" until the aux tank empties, then guage works as per normal.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17913 ![]() ![]() ![]() |
FWIW, I think the crossmember will also fit a Puma, it certainly looks the same.
Bump....open to offers on both items
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
It hasn't got the "Am I missing a gearbox mount?" Bracket. But yes, looks the same
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
^^^^ ah, this was a special order crossmember to ease the minds of puma owners who thought there was a bracket missing.
It's now worth twice as much ![]() ![]() |
Fuel tank now binned.
