Home > For Sale & Wanted > [For Sale] 110 under-arch fuel tank and Td5 crossmember
I'll post some piccies up later, but I have:
a 110 rear "under arch" auxiliary fuel tank. It's the "flow through" type, where you cut the filler pipe at either end and this tank (snugly) fits in.
Now, I got it second hand, covered in grime. Got it shotblasted and there's a few holes in it (mainly where mud had built up on it), pictures will show this, but being as it's more or less "square" shaped and flat sides, then getting some plate cut to size and re-welded in won't be an issue (if I had the time and inclination I'd do it myself, but I have neither Laughing )
Tank comes with the filler pipe adaptor bit as well
I'll be looking for £60 for it.
Also have an undamaged but used Td5 gearbox crossmember; the bolt in "flat" bottomed type. £15
Both items are in Swindon. Postage will be quite high (especially for the tank) so collection is more than welcome, or if I'm around anywhere when at work that's near to you then we can sort something out.
cheers
Post #645589 22nd Aug 2017 7:41am
Photo's as promised.....
And the crossmember:
Post #645660 22nd Aug 2017 2:14pm
Rusty marks are just surface rust as it's been shotblasted, so bare metal, and it's been sat in my garage for a while.
Post #645662 22nd Aug 2017 2:21pm
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
So the tank fits inside the tub and fills once the main tank is fill. Then slowly drains into the main tank...
Is that correct?
It basically takes up the rear corner of the tub...
Think it will fit a 130?
Post #645677 22nd Aug 2017 4:29pm
Yes, I think the proper term for them is "fill through", so you stick the pump nozzle in the usual filler, pump away, fuel will flow through the aux tank, then into the main tank... main tank fills to the brim then starts to fill the aux tank.
So, your fuel guage won't move until the aux tank runs empty. I suppose some mileage calculations will need to be worked out so you can tell when the aux tank has emptied.
There is a balance pipe than can be fitted (see extra pics below), which is supposed to stop an air lock that can occur; but I've heard that others with a fill through tank don't have them fitted and have no problems.
Post #645683 22nd Aug 2017 4:58pm
Finally sussed out how to add photos from my album!
Post #645686 22nd Aug 2017 5:13pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
No idea about the defender but my TD5 Disco gauge would trip out and show empty with full warning light on when both tanks were full, then as the aux tank emptied out it would go mental and finally settle down to full. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #645735 22nd Aug 2017 9:17pm
I'm pretty sure defenders just sit at "full" until the aux tank empties, then guage works as per normal.
Post #646025 24th Aug 2017 7:52am
FWIW, I think the crossmember will also fit a Puma, it certainly looks the same.
Post #646036 24th Aug 2017 9:16am
Bump....open to offers on both items
Post #701434 17th Apr 2018 7:52am
grafty99
It hasn't got the "Am I missing a gearbox mount?" Bracket. But yes, looks the same Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #701435 17th Apr 2018 8:01am
^^^^ ah, this was a special order crossmember to ease the minds of puma owners who thought there was a bracket missing.
It's now worth twice as much Laughing Laughing
Post #701472 17th Apr 2018 11:51am
Fuel tank now binned.
Post #702248 21st Apr 2018 10:39pm
