![]() | Home > Puma (Tdci) > 2012 difficult to start |
justinp Member Since: 24 Jun 2016 Location: Cambridge Posts: 167 ![]() ![]() |
Following a trip to the dealer where I was predictably told they could not reproduce the cranking issue, I decided to have a go myself.
Two weeks ago I tightening the earthing bolt on the transfer box about a 1/4 turn, I also re-seated the spade connectors on the ignition switch. Since then the issue has not occurred again. The fault may return, but so far so good. Now gone - 2012 2.2 110 DC XS |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello justinp
Let's hope you have sorted it... ![]() Another possible problem area could be the Starter Relay, it may just be 'breaking down' or have poor 'intermittent' connections...(No. 3) ![]() Click image to enlarge I had a similar starting issues (more all or nothing but the occasional 1 second of life then nothing) that was down to a rear connector on the ignition switch... http://www.defender2.net/forum/topic56604.html Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
