![]() | Home > Maintenance & Modifications > Rusted Doors |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
You can buy repair sections, I think YRM do them.
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
i took my passenger side door card off on weekend quickly put it back on lol, they look pretty bad at the bottom
![]() Who are YRM? |
YRM make various repair sections as well as other small parts for Land Rovers. Do a Google search and you will find them.
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 584 ![]() ![]() ![]() |
https://yrmit.co.uk/
![]() Marc |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
I ended up going for complete new doors from http://www.sp-4x4.com/category_s/242.htm and took the galvanised option with a zinc plated steel skin. Not cheap but great quality.
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
My doors were not good at the bottom, 2003. I didn't want to remove them to have a new section fitted so opted for a repair which should give me a few more years. I drilled out the pop rivets that hold the rubber seal to the bottom of the door and painted the door bottom with silver rust preventative POR15 paint from frosts and sprayed the internal section with Dintrol 3125HS. I fitted a new rubber seal. For the plastic sheet I bought some heavy duty sheet from screwfix. I still need to find an alternative for the silly self adhesive foam blocks at a decent price. Some of the fixings on the door card broke, the yellow plastic that hold the Xmas tree fittings. I used 6x3/8 stainless tappers which worked a treat. I got these from Kays via ebay. A 3mm pilot hole worked well.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
