Home > Maintenance & Modifications > Rusted Doors
tjwest10
United Kingdom 1988 Defender 90 2.5 TD HT Portofino Red
Rusted Doors
What is the best/cheapest way to fix doors that are rusted at the bottom?
For the most part, they are in great shape. However, I am worried about further rusting and am trying to decide whether I need brand new doors or whether there is an easier and cheaper fix...
Post #619803 26th Apr 2017 10:59pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
You can buy repair sections, I think YRM do them.
Post #619814 26th Apr 2017 11:19pm
Djcla
i took my passenger side door card off on weekend quickly put it back on lol, they look pretty bad at the bottom Sad . Im wondering what the cheapest way is to repair them , is it just a skin you need?
Who are YRM?
Post #644434 16th Aug 2017 2:07pm
defender9
YRM make various repair sections as well as other small parts for Land Rovers. Do a Google search and you will find them.
Post #644508 16th Aug 2017 7:22pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Post #644519 16th Aug 2017 8:08pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I ended up going for complete new doors from http://www.sp-4x4.com/category_s/242.htm and took the galvanised option with a zinc plated steel skin. Not cheap but great quality.
Post #644528 16th Aug 2017 8:23pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
My doors were not good at the bottom, 2003. I didn't want to remove them to have a new section fitted so opted for a repair which should give me a few more years. I drilled out the pop rivets that hold the rubber seal to the bottom of the door and painted the door bottom with silver rust preventative POR15 paint from frosts and sprayed the internal section with Dintrol 3125HS. I fitted a new rubber seal. For the plastic sheet I bought some heavy duty sheet from screwfix. I still need to find an alternative for the silly self adhesive foam blocks at a decent price. Some of the fixings on the door card broke, the yellow plastic that hold the Xmas tree fittings. I used 6x3/8 stainless tappers which worked a treat. I got these from Kays via ebay. A 3mm pilot hole worked well.
Post #644563 16th Aug 2017 9:30pm
