Home > Maintenance & Modifications > Comfort: Post TD5 vs Pre-puma seats
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I'm weighing up whether to start looking for puma front seats or buy new foam for bases of my current seats.
Are the post td5 seats more comfortable than the Tdi/Td5...etc type? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #643878 14th Aug 2017 4:00pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
No.
Post #643881 14th Aug 2017 4:14pm
mk1collector
Post #643884 14th Aug 2017 4:24pm
Kit
Rolling with laughter 1993 200 Tdi 90 CSW
Post #643889 14th Aug 2017 4:45pm
Yes. Whistle ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #643892 14th Aug 2017 4:58pm
Lightningtweeds
Mite be then...
Post #643893 14th Aug 2017 5:00pm
X4SKP
Hello Kit
Depending on Spec', i'd say possibly the answer is yes...but don't rush to spend your money.
On the left was my 300tdi, with 120K on original seats, the foam inserts were just showing signs of
needing replacing, (losing shape and foam 'powdering' up / breaking down).
On the right is my 2.4 Puma, with 30K on original seats. I was told (by Land Rover) that the foam used
post 2007 (Puma >) is slightly stiffer. It's marginal, but I'd say this appears to be true. What I do like
and does make a difference, is my newer seats have a higher back and this together with the taller side
elements, help to give the feeling that you are sitting 'in' rather than 'on' these seats.
The Leather / Alcantara V's Cloth / Vinyl also helps to lift things...
I was perfectly happy (and comfortable) with the 300tdi Seats, but the 'evolution' of changes
in the Puma Seats (Foam (if true) and height) and Material Finishes (depending on Spec') is an improvement.
A good friend has a TD5 and I'd say these seats feel like my 300tdi, (someone on here will know)
So may be more of a 'perceived improvement' than a 'significant' one, but in any case I'm happy to be sitting
where I am now.
Wife says 'definitely better'...so there we have it Exclamation SKIP
Post #643895 14th Aug 2017 5:02pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I upgraded my td5 seats to puma ones and wouldn't go back found them more supportive and comfortable 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #643907 14th Aug 2017 6:09pm
miker
Just refoamed my TD5 drivers seat and it's a vast improvement on the old foam! Not sat in a more modern defender so can't offer any opinions there I'm afraid.
Post #643909 14th Aug 2017 6:11pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Yes, but mine came with the upgraded high back seats the same as these
 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #643939 14th Aug 2017 7:36pm
zsd-puma
You're still not talking Range Rover levels of comfort, but yes the standard Puma ones are a little better than the earlier ones. However The foam does wear and split along the side bolsters.
It's probably cheaper just to buy uprated foams and covers from Exmoor and improve your exisiting seats. I think they do improved padding and trim for the earlier seat frames.
Post #643944 14th Aug 2017 8:21pm
L110CDL
Ever since i bought millie, 300Tdi, the original seats have done me proud, i was use to them and thought this was good until i put a set of xs seats in ( in under what did you do in your defender today section ) and what a difference, they are sooooo comfy and will not be going back to the originals very quickly Wink i have never sat in a newer defender so i dont know Shocked Clayton.
Keeper.
Post #644008 14th Aug 2017 10:26pm
AMBxx
I found the Puma XS part leather seats just gave me a numb backside as the base is now too short for the extra depth in the back of the seat.
Replaced with extended seat bases. Greater height is a pain, but much more comfortable.
If anyone would like to buy my old seat bases, they're in the for sale forum. Exclamation
Post #644090 15th Aug 2017 9:51am
