Page 1023 of 1395 <123 ... 102210231024 ... 139313941395>
L110CDL
Procta wrote:
nice to see her go through a test with out anybother! My dads was picked on for that same reason with the seat belt, and mine failed on it last year, i thought it was the nearside one, but it was the drivers that was the failure.
Lovely colour blue that is mined L110CDL
I had to have a new seat belt on the o/s as it was getting bad after 21 years of use Laughing at least the n/s one will last a bit longer Wink
Many thanks about the colour, its called Gulf Blue and is a VW colour Thumbs Up Clayton.
Keeper.
Post #640613 29th Jul 2017 10:26pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Having got my 110 back from the dealer (Roger Young in Saltash - 10/10 for service and support) I handed back the 'estate car' that I have been using for the last week (Disco Sport) - I like the speed limiter that kept me right when in potting around towns and villages!
I have now started to fit the new parts that arrived recently
Diesel powered planar air heater and under cubby box mount from our german sponsor, Nakatanenga
Glove box conversion from MSS, with new USB plugs to be fitted in the glove box
And a Panasonic DAB radio with aerial splitter and bluetooth hand free with aux and USB links to be fitted in the glove box
Started on the radio and its in and works really well with the aerial splitter that picked up DAB in the backwoods of Cornwall first time! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #640647 30th Jul 2017 7:48am
Procta
the day before I gave mine a oil change plus the two filters, and yesterday I installed my replacement Heat shield thing that goes just beside the turbo.
not exciting sadly but I am working on it Embarassed Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #640702 30th Jul 2017 1:03pm
Bluest
I modified the bolts in my Mantec wheel carrier so I can grease the hinges easily. I saw that the Masai carrier comes like this, which gave me the idea. Hole drilled down the centre of the bolt, tapped for a grease nipple and cross drilled about half way down.
They seem to work well, with grease oozing out of the hinges after a few squeezes with the grease gun.
And the nipple is hidden under the standard cap, which keeps it out of the elements.
 2007 110 TDCi Station Wagon XS
Post #640709 30th Jul 2017 2:34pm
Stacey007
OK so full service, new Steering damper, Poly PanHard rod bush, new drive flanges, Spacers on. Love the stance... feels like a new truck also, and the lock is better Smile
Then today I thought... I have some dirt defenders somewhere I bought off a forum member ages ago... and I did, just fronts but for now better than nothing. (found in a bag in my Sankey trailer)
So need rears now Very Happy
Post #640718 30th Jul 2017 3:53pm
JOE_130
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Java Black
130 did me proud at the weekend towing and launching the RIB. Picture courtesy of Matt110 Smile
130 definitely feels more planted, longer wheelbase helps over our 90 I normally use to do this!
Post #640883 31st Jul 2017 12:02pm
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
took mine away for a weekend camping a couple of weeks ago
This was the first real test of the LS conversion and it was pretty much faultless. Until the Thursday night we left it had done about 250km with the longest run being about 30ks.
It did 275km each way with the only issue being it runs a bit warmer than I would like so I will swap the rad shortly.
Its a different world from the remapped TD5. 400BHP makes it effortless everywhere!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #641055 1st Aug 2017 5:36am
wyvern
Cabin Air Heater fitted and running - took about one full day and started with no problems even with my limited mechanical skills and small tool kit.
The only small issue was the landrover fitted sub woofer mounted on the back of the cubby box cable that had to be re-routed from under the box to the side, , and then an hour or so searching for an english version of the heater control manual on the internet.
Fuel and battery tie ins were simple, I was able to use available mountings on the chassis with out any drilling required.
The only drilling needed was to make new holes in the bottom of of the cubby box to mount on the top of the heater frame.
It took 3 starting cycles to prime the pump and start the unit.
Next job is the glove box unit !
Post #641061 1st Aug 2017 6:44am
I recognise that unit Very Happy
Post #641068 1st Aug 2017 7:13am
wyvern
Hi Steve
Sadly no - this is a brand spanking new Planar one supplied from Germany ... the one I had from you is still in the grey 110 and going great guns when I sold it ... I would have loved to have kept it but time and work just got in the way so it has gone to a new home - Sad
However this unit is very very similar in its looks and time will tell how it performs against the Airtop ... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #641083 1st Aug 2017 7:53am
AJC
Awesome work, does the kit come with everything to fit to the defender? it's something I've been thinking of doing for a while.
Post #641145 1st Aug 2017 1:02pm
AJC
Cracking idea Mr. Green Mine squeeks every now and then, never though of doing this
Post #641146 1st Aug 2017 1:04pm
Devon-Rover
Time for the Bi-monthly propshaft UJ greasing
Post #641149 1st Aug 2017 1:24pm
wyvern
Hi AJC
Yes - had the kit shipped from Nakatanenga in Germany directly and it had everything included - the site was in german so took a little bit of time to translate each part but delivered in good order and fitted with no additional parts needed .
Make sure you specify you have a defender puma and then chose which controller you would like - I have the one with a timer on it so as I can start the heater in the mornings when its cold.
Next job is 2nd battery and split charger ... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #641158 1st Aug 2017 2:17pm
AJC
Thanks for the reply, I have a TD5. I will look on the Nakatenga site. cheers
Post #641171 1st Aug 2017 3:23pm
