|  | Home > Technical > Heater blower fan |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | heater motor is seized do to water
 check heater air inlet drain is not block with moss you may be able to free it up WD40 or fit new motor | ||
|  26th Jul 2017 9:27am |
| gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654      | if its a td5 the motor cost a small fortune compared to earlier ones as you have to buy the full heater box and can't get just the motor.
 How ever if you get a cheaper early fan you can grind and cut some of the locating pegs and then drill and rivit the remaining ones. It cost me about 70 quid vs about 240 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r | ||
|  26th Jul 2017 9:36am |
| timtom1 Member Since: 10 Jul 2012 Location: Lancashire Posts: 148      | Thanks for the reply guys, I've tried again to move the fan by hand still no joy.
 I can't seem to find any TD5 Heater Assembly boxes anywhere not even on ebay? Its really annoying I can't just change the fan motor. Does anybody have any part numbers? Here is a pic through the top vent.   Click image to enlarge Does it look out of line, knackered? Thanks Tim 2001 90 TD5 CSW Alveston Red Manual | ||
|  26th Jul 2017 10:48pm |
| gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654      | fit a fan from a earlier model 200 or 300 it's not hard to make it fit and seal. It does involve grinding, drilling and riveting but it's not hard 2014 - current ..... 2003 defender td5 90 (my car)
|  26th Jul 2017 11:04pm |
|  26th Jul 2017 11:06pm |
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2416      | I'd give that a really good spray of WD40 straight down the hole twice a day for 2 or 3 days, trying to turn it by hand each time. I have freed off several this way.
 HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey | ||
|  27th Jul 2017 5:04am |
| timtom1 Member Since: 10 Jul 2012 Location: Lancashire Posts: 148      | Thanks guys, being a novice I will try the WD40 for a few days. If not I will take out the Heater Box Assembly.
 I assume the earlier motors have the same electrical connectors? THanks Tim 2001 90 TD5 CSW Alveston Red Manual | ||
|  27th Jul 2017 5:06pm |
| timtom1 Member Since: 10 Jul 2012 Location: Lancashire Posts: 148      | The fan now moves by hand after lots of WD40      However I tired the blower and it still didn't work,  I will borrow a multimeter from work tomorrow and check the connections and switches, and hope its one of them.... Thanks for the help guys 2001 90 TD5 CSW Alveston Red Manual | ||
|  27th Jul 2017 9:09pm |
| timtom1 Member Since: 10 Jul 2012 Location: Lancashire Posts: 148      | I'm not getting 12v on the purple /green wire connecting to the bulkhead or the 3 way connector switch or at the blower switches at the dash.
 However I am getting 12v at the fuse box? 2001 90 TD5 CSW Alveston Red Manual | ||
|  30th Jul 2017 7:42pm |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027      | Does it go through a relay? 2023 Defender L663 V8
 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) | ||
|  30th Jul 2017 7:52pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  |   Click image to enlarge you also have wire wound resistor speed control pack | ||
|  30th Jul 2017 8:05pm |
| timtom1 Member Since: 10 Jul 2012 Location: Lancashire Posts: 148      | can I check anything else before taking out the heater assembly box and resistor?
 No relay, is feed directly to the heater assembly box 2001 90 TD5 CSW Alveston Red Manual | ||
|  30th Jul 2017 9:56pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | wire wound resistor speed control pack  is in the top of fan
 check that dash switch and wiring good order | ||
|  31st Jul 2017 7:27am |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
