Home > Technical > Heater blower fan
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
Heater blower fan
Hi all
My heater blower fan has stopped working, and blew a fuse which I changed, so the cigarette lighter is now working again. However when it went it made a very strange noise under the bonnet so I undid the cowl and tried to turn the fan by hand but it won't turn?
How easy is it to replace the fan once the heater unit is out?
Thanks
Tim 2001 90 TD5 CSW Alveston Red Manual
Post #639803 26th Jul 2017 8:58am
dorsetsmith
heater motor is seized do to water
check heater air inlet drain is not block with moss
you may be able to free it up WD40 or fit new motor
Post #639809 26th Jul 2017 9:27am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
if its a td5 the motor cost a small fortune compared to earlier ones as you have to buy the full heater box and can't get just the motor.
How ever if you get a cheaper early fan you can grind and cut some of the locating pegs and then drill and rivit the remaining ones. It cost me about 70 quid vs about 240 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #639811 26th Jul 2017 9:36am
timtom1
Thanks for the reply guys, I've tried again to move the fan by hand still no joy.
I can't seem to find any TD5 Heater Assembly boxes anywhere not even on ebay?
Its really annoying I can't just change the fan motor.
Does anybody have any part numbers?
Here is a pic through the top vent.
Does it look out of line, knackered?
Thanks
Post #640011 26th Jul 2017 10:48pm
gazman
fit a fan from a earlier model 200 or 300 it's not hard to make it fit and seal. It does involve grinding, drilling and riveting but it's not hard 2014 - current ..... 2003 defender td5 90 (my car)
Post #640018 26th Jul 2017 11:04pm
gazman
Post #640021 26th Jul 2017 11:06pm
Mo Murphy
I'd give that a really good spray of WD40 straight down the hole twice a day for 2 or 3 days, trying to turn it by hand each time. I have freed off several this way.
HTH
50 Shades of Pennine Grey
Post #640038 27th Jul 2017 5:04am
timtom1
Thanks guys, being a novice I will try the WD40 for a few days. If not I will take out the Heater Box Assembly.
I assume the earlier motors have the same electrical connectors?
THanks
Post #640144 27th Jul 2017 5:06pm
timtom1
The fan now moves by hand after lots of WD40 Thumbs Up
However I tired the blower and it still didn't work, Big Cry I will borrow a multimeter from work tomorrow and check the connections and switches, and hope its one of them....
Thanks for the help guys 2001 90 TD5 CSW Alveston Red Manual
Post #640193 27th Jul 2017 9:09pm
timtom1
I'm not getting 12v on the purple /green wire connecting to the bulkhead or the 3 way connector switch or at the blower switches at the dash.
However I am getting 12v at the fuse box? 2001 90 TD5 CSW Alveston Red Manual
Post #640751 30th Jul 2017 7:42pm
bear100
Does it go through a relay? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #640756 30th Jul 2017 7:52pm
dorsetsmith
you also have wire wound resistor speed control pack
Post #640761 30th Jul 2017 8:05pm
timtom1
can I check anything else before taking out the heater assembly box and resistor?
No relay, is feed directly to the heater assembly box 2001 90 TD5 CSW Alveston Red Manual
Post #640792 30th Jul 2017 9:56pm
dorsetsmith
wire wound resistor speed control pack is in the top of fan
check that dash switch and wiring good order
Post #640832 31st Jul 2017 7:27am
