![]() | Home > Td5 > What ECU do I have? Cruise control? |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
If your ecu has a part number of NNN------ then you can fit cruise, if you have MSB------ you cant.
Pete |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Like Pete said, it will only work with the NNN type ECU. It will work on a older TD5 with the newer NNN type ECU fitted. There should be a sticker or two on it saying what the part number is. If you have a NNN type then drop me a line and i'll sort you out a kit if you need one.
Pete. |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 ![]() ![]() ![]() |
Thats great I will have a look in the morning and Ill be in touch. Thanks lot
landyahct Member Since: 19 Jul 2017 Location: Lincolnshire Posts: 2 ![]() ![]() |
hi are these still available Pete?
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Recommend you post the part number of each ecu here or just post a picture of both stickers on the ECUs.
Pretty sure you will get a definitive answer after that. Patrick |
Mine is indeed an NNN type ECU.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3245 ![]() ![]() |
This thread dates from 2011 !!
I believe the later TD5 only needs a wiring harness and two buttons, "set" and "resume" There used to be a kit for about £140 but it has disappeared. I'd fit it to mine but l'm not paying £450 for the kit with ECU which l am told you don't need. |
I paid about 5 euro's for 2 push buttons. You can easily find a schemaic on the web. And as I changed my engine loom I had pleny off wire and plug connector parts. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
I am goin to swap my ecu to the newer nnn, add some pigtails to the black ecu plug and use the disco 2 controls for a nice clean finish.
There is a cheap terrafirma 150pound kit on some websites, but who can beat factory buttons... |
