Home > Td5 > What ECU do I have? Cruise control?
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
I have a 1999 td5 and I was told that it had been fitted with a remapped ECU. I have the original ECU also.
My question is I am interested in fitting cruise control and I am aware that you can buy a kit for certain models years. I know that the kits do not work on 1999 models with the standard ECU.
What year ECU would a cruise control kit work with and how can I tell what year mine remapped one is?
Hope this makes sense Question
thanks in advance Thumbs Up
Post #78417 29th Jun 2011 9:18pm
bell-auto-services
If your ecu has a part number of NNN------ then you can fit cruise, if you have MSB------ you cant.
Pete
Post #78433 29th Jun 2011 10:45pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Like Pete said, it will only work with the NNN type ECU. It will work on a older TD5 with the newer NNN type ECU fitted. There should be a sticker or two on it saying what the part number is. If you have a NNN type then drop me a line and i'll sort you out a kit if you need one.
Pete.
Post #78436 29th Jun 2011 10:48pm
amondeggs
Thats great I will have a look in the morning and Ill be in touch. Thanks lot
Post #78444 29th Jun 2011 11:34pm
landyahct
td5 cruise control kits
hi are these still available Pete?
Post #638533 19th Jul 2017 10:33pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Recommend you post the part number of each ecu here or just post a picture of both stickers on the ECUs.
Pretty sure you will get a definitive answer after that.
Patrick
Post #638616 20th Jul 2017 2:11pm
landyahct
Mine is indeed an NNN type ECU.
Post #638725 21st Jul 2017 12:30am
lightning
This thread dates from 2011 !!
I believe the later TD5 only needs a wiring harness and two buttons, "set" and "resume"
There used to be a kit for about £140 but it has disappeared.
I'd fit it to mine but l'm not paying £450 for the kit with ECU which l am told you don't need.
Post #638806 21st Jul 2017 3:45pm
roel
I paid about 5 euro's for 2 push buttons. You can easily find a schemaic on the web. And as I changed my engine loom I had pleny off wire and plug connector parts. Roel
2003 90 Td5 (2009-now)
Post #639162 23rd Jul 2017 3:58pm
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
I am goin to swap my ecu to the newer nnn, add some pigtails to the black ecu plug and use the disco 2 controls for a nice clean finish.
There is a cheap terrafirma 150pound kit on some websites, but who can beat factory buttons...
Post #639327 24th Jul 2017 4:27am
