^ That would be correct yes...
I still think if we get a van I need to change my set up to a proper dixon bate, that way I can get a additional slider for the nato hitch.
Thanks
12th Jul 2017 8:12am
Dasher
My first thought was to hitch up with the door open too - but in my case I couldn't close it again past the jockey wheel winder. The 'A' frame on these Bailey's is very short (some would say 'compact').Removable handle sorted all the issues.I'm using the lowest set of mount holes.
12th Jul 2017 9:03am
Rallymental
We tow Bailey Ranger 460/2 GT65 with DB with the slider set to the lowest level. I have to hitch with the door open then close it after applying the stabiliser but have never had a problem with it fouling on the handbrake or the jockey wheel provided you shut the door before raising the jockey wheel to the travel position.
Click image to enlargeThe definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
