Home > Puma (Tdci) > Indicator flash on locking the vechile
s18mcn
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
When I got my defender when I locked it or unlocked the indicators used to flash now it doesn't??? I've checked fuses anybody else had this problem??
Post #63434 12th Mar 2011 6:58pm
dgardel
Italy
Wrote on user manual: you need to change the battery of the remote.
10AS (alarm ECU) show you without lamps blink that the battery is low. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #63439 12th Mar 2011 7:15pm
s18mcn
Thankyou very much. Typical man don't bother reading the manual!!!!
Post #63444 12th Mar 2011 7:29pm
dgardel
Italy
Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #63461 12th Mar 2011 9:01pm
funrover
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
dgardel wrote:
Thumbs Up Thumbs Up
Do you know if a low remote battery can also cause the horn to sound on locking (TD5)? Editor of FunRover - One blog. Read it!
Land Rover rebuild video series here:
Post #63514 13th Mar 2011 11:34am
dgardel
Italy
Mhmmm
I do not know......
May be a door/bonnet switch faulty? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #63515 13th Mar 2011 12:13pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
funrover wrote:
dgardel wrote:
Thumbs Up Thumbs Up
Horn didn't sound on my Td5 when I recently had to replace the blipper battery - was just the lack of indicator flash on locking.
My horn sounds on locking when a door/bonnet hasn't shut fully, so as Dgardel says, perhaps a dodgy switch ? Jon - 110 td5 [sold]. Currently Defenderless.
Post #63521 13th Mar 2011 12:40pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
TD5 horn sounds if one of the doors isn't closed properly. as mentioned above, prob faulty door microswitch
Post #63580 13th Mar 2011 8:21pm
funrover
Cheers guys! Will replace those Wink Editor of FunRover - One blog. Read it!
Post #63642 14th Mar 2011 9:41am
s18mcn
Quick update! I've changed the battery in the remote it now locks and unlocks better but still no indicator flash????? Any ideas????
Post #63703 14th Mar 2011 7:19pm
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Is there any way of increasing the distance the remote works from? Mine seems to be really close, does my head in?!! Cheers
Post #63924 16th Mar 2011 3:03pm
TJ101
The search button is your friend Thumbs Up http://www.defender2.net/forum/topic5854-15.html for one California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #63947 16th Mar 2011 5:23pm
Jammer600
Ha ha, cheers, a newbee here Smile
Post #63985 16th Mar 2011 8:14pm
