![]() | Home > Puma (Tdci) > Indicator flash on locking the vechile |
Wrote on user manual: you need to change the battery of the remote.
10AS (alarm ECU) show you without lamps blink that the battery is low. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
s18mcn Member Since: 11 Feb 2011 Location: cambs Posts: 53 ![]() ![]() ![]() |
Thankyou very much. Typical man don't bother reading the manual!!!!
![]() ![]() ![]() IID Pro MV License |
funrover Member Since: 12 Dec 2010 Location: Yorkshire Posts: 130 ![]() ![]() ![]() |
Do you know if a low remote battery can also cause the horn to sound on locking (TD5)? Editor of FunRover - One blog. Read it! Land Rover rebuild video series here: |
Mhmmm
I do not know...... May be a door/bonnet switch faulty? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Horn didn't sound on my Td5 when I recently had to replace the blipper battery - was just the lack of indicator flash on locking. My horn sounds on locking when a door/bonnet hasn't shut fully, so as Dgardel says, perhaps a dodgy switch ? Jon - 110 td5 [sold]. Currently Defenderless. |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
TD5 horn sounds if one of the doors isn't closed properly. as mentioned above, prob faulty door microswitch
Cheers guys! Will replace those
![]() Land Rover rebuild video series here: |
Quick update! I've changed the battery in the remote it now locks and unlocks better but still no indicator flash????? Any ideas????
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
Is there any way of increasing the distance the remote works from? Mine seems to be really close, does my head in?!! Cheers
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
The search button is your friend ![]() Main Brian James Trailer Dealer for South West UK |
Ha ha, cheers, a newbee here
