![]() | Home > Maintenance & Modifications > Side steps, what do you have? |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 97 ![]() ![]() ![]() |
Fold ups, that stay folded up and collect muck
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
On our '13 90 we have the factory option black tube item with silver chequerplate
Pickles. |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1910 ![]() ![]() |
Genuine, retro fitted by me
![]() ![]() Click image to enlarge Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top Last edited by CarMan on 20th Jul 2017 9:03am. Edited 1 time in total |
BCdefender Member Since: 26 Oct 2015 Location: Nanaimo Posts: 211 ![]() ![]() ![]() |
I ended up going with the galvanized terrafirma rockslides/tree guards and had them powder coated. Also put on grip taped to avoid the tibia impaction fracture! These seemed like the best option because they don't affect clearance. 1999 Defender 110
2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Stainless tubular on mine, not much of a step but at least they don't rust like the originals
![]() ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
Genuine SVX sidesteps. 9 years young and as new.
Eric ![]() Click image to enlarge ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge Stainless steel twin tube on the 90, replaced the rusted out black version that it had on it and fire and ice style on the 110 |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2231 ![]() ![]() ![]() |
Dixon Fabrications tubular rock sliders, coated in Raptor & sand for grip.
I wouldnt fit anything else tbh the added side impact protection for on road driving alone is reason enough |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2542 ![]() ![]() ![]() |
Ian series 1. I do like your stainless "steps". Did you have them made or were they off the shelf? Defender 90XS SW
Off the shelf.
![]() https://www.googleadservices.com/pagead/ac...amp;adurl= 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
None 👍 Solved the bowel problem, working on the consonants...
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
Think I will be looking at the version the same as Carman has, Genuine.
Pricy though as per LR but seem pretty good. I'd be inclined to drill a small hole in the plastic end caps, and tap a thread and use a Stainless fixing as a removable cap to use Dintitrol internal wax on and off. I can see the merits of stainless, but I don't like bare stainless and the rest is mild steel but painted so that isn't a problem to me. Time to put the pennies away, lots of them by the looks of it. ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
We optioned the factory side steps on our '13 Puma 90,..option "048AP".
There is some confusion as to what actually are the correct items as there are some that look somewhat the same, but aren't. In view of some comments & images that I've seen on this forum regarding durability etc, I bought myself a spare set, which couldn't be bought as a set, only individually. The part numbers are LR029295(RHS) & LR029297(LHS). I also bought the supporting struts. Not cheap. Pickles. |
